This prefab metal fireplace with a metal flue had this gas burner with metal grate over it.... Not sure about this setup... comments please
Missing logs? Cheap source of flames? B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
It appears to be missing some parts.
Verify with the manufacturer's installation instructions or refer it to a qualified professional would be my thoughts. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Could it be a gas starter for a wood burning fireplace?
That's what I was going to say; gas fired starter rather than a gas log set.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
White bricks are awful clean looking for every having had actual wood products burned in there. My bet is on missing gas logs.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
I don't see any mention if the FP had ever been used before.
The supply line usually comes in from the side, through a knock-out. Was this a custom drilled opening in the bottom of the firebox?
The picture was just for the crack in the "firebrick" material.
The gas line was on the right and looked normal from what I can remember. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Bruce,
FYI: the "firebrick" material is not fire brick it is the refractory they generally come in three pieces and are a pre-cast cementitious product. Broken refractory at the back or side(s) voids the UL rating this may create a combustion hazard and this unit shall not be used for any reason until this is replaced with a new refractory. Consult ... The metal firebox should have a label with mfg. ID and model I'll note this so when I've left the inspection I can look up if further info is required and so client can mail for or download instructions, which are usually long gone. The unit in you pic may or may not allow combustibles other than gas but many are not installed properly and many do not come with log kits (optional accessory). If that's ever had a fire of any type it must have been a candle centered directly under the flue damper. Was a damper block present? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 12/4/07 at 7:17 AM.. |
| The Rumford Fireplace: Safety vs. Efficiency | mbryan | Interior Inspections | 2 | 4/28/08 5:38 PM |
| grounding on plumbing | gmathias | Electrical Inspections | 7 | 8/17/07 3:22 PM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 8:22 PM |
| Fireplace / Direct Vent problem | srowe | Inspecting HVAC Systems | 4 | 2/16/06 2:29 PM |
