Any Reg. indicating that PT material can not be used for interiors, example:as a support post or carrying beam in a living room?
Thanks, Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
Maybe the question should be instead, why would they use such a crappy-looking piece of lumber?
Not that I know of, but it's a safety issue becuase of the toxic chemicals in pressure-treated lumber, so it should be mentioned in the report. Much more of an issue in households with small children.
I think if I saw PT lumber used in the interior of the house I'd be very concerned as to the workmanship throughout. Obviously a homer special has been spending his weekends poorly. I would think there is a very different drying process for PT wood and as such shrinkage could cause a lot of problems especially when it is used for structural thoughts?
If pressure treated lumber is found inside a home, it doesn't have to be removed. I believe pressure-treated lumber is safe once it's covered with a heaping portion of oil-base primer followed by one or two more coats of your favorite colored oil-base finish.
| The Rise and Fall of CCA Wood Preservatives | mcyr | General Inspection Discussion | 3 | 5/4/08 11:19 AM |
| Preventing Moisture related Problems | mcyr | Ancillary Inspection Services & Additional Topics | 1 | 12/19/07 8:30 AM |
| Pressure Treated Wood Basements | lkage | Structural Inspections | 4 | 8/22/06 5:14 PM |
