Old 7/25/07, 9:42 PM
nwagner's Avatar
nwagner nwagner is offline
Default Pull Down Staircase Installation
Looking for good materials on the proper installation of pulldown staircases ...
Old 7/26/07, 12:54 AM
Unmoderated Guest
Default Re: Pull Down Staircase Installation
There isn't any cut-and-dry method. You will no doubt have to cut at least one ceiling joist and maybe up to three, depending on the direction of the joists, their spacing, and the direction that the folding stair must take. Depending on the span, depth, spacing and species and grade of wood used for the joists, and the position of the access stair relative to the joist supports, you'll have to header the ends of the opening, maybe with a single piece, or maybe a double, and you may also have to double up the joists on the sides, or maybe add another joist or two bwteeen two existing joists, and install joist hangers. So what I'm saying is, it could range from structurally very simple to structurally complicated, depending on all those factors.
I'm not saying you need an engineer, but at least the advice of someone who is well experienced in framing should be sought, if you do not have such expertise. If you know a good engineer or a competent architect, so much the better. Or you might find an architect or engineer who will treat this as a routine consulation and do it either very inexpensively, or as I would, for no charge. It only takes about a minute to do the calculations required. Good luck.
Old 7/26/07, 7:19 AM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Find a manufacturer and get the instructons from there. that is the easiest thing to do. I can tell you that in my area that 80-90% are installed incorrectly in some way. The items I find most are:
  • Improper nails or screws. I often see drywall or deck screws used not the proper 16d nails or 1/4"x3" lag screws.
  • Improper nailing pattern. Many times manufacturer will have sticker that says, "PUT NAIL HERE DUMMY"
  • Legs not cut properly.
  • Frame not headed off properly
  • Gaps at hinges
  • Loose hinge bolts
Hope this helps
pull-down-staircase-installation-ladder-nail-vs.screw.gif   pull-down-staircase-installation-garage.access.jpg
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 7/26/07, 11:23 AM
Barry Adair's Avatar
Nick,
Numerous guides and instructions available here:
http://www.google.com/search?sourcei...allation+guide
FYI this is not DIY, unless you are very familiar with ceiling/roof structure framing.
Hell, half or more that I see installed by "professionals", using that term VERY loosely, are wrong in some form or fashion and compromising the structural integrity has been posted on numerous threads, concerning these.
Nice graphic Shawn but you need one with the drywall screws through that label
I'll look for one.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 7/26/07, 12:10 PM
Banned
Nick:
You're in Wisconsin with high winter degree days......I'd recommend replacing them with a pre-built weatherstripped, insulated attic hatch (unless the attic is a heated area). Pull down stairs are about the most inefficient things I have seen......hard to weatherstrip and insulate well.
Old 7/26/07, 1:23 PM
Peter C. Russell's Avatar
Brian, here is an example of just what you described except in reverse.
The attic temp. was 146f and the heat was just coming through the pull down stair, imagine the heat loss in the winter.
Old 7/26/07, 2:36 PM
Banned
Peter:
If the 98.1 deg registering in the upper left of the image is the lower surface temperature of the stairs hatch, then it's time to do something. That temp is in the operating range of radiant ceiling heat.......no need to have it "on" in the summer to drive the A/C system into overtime. Thanks for the image.
Old 7/26/07, 3:48 PM
No problem Brian, I should have had my range and focus set better on the camera, but I'm just getting use to it. The client said this is the hardest room in the house to heat, wonder why?
Also found missing insulation in the kitchen ceiling.
Old 7/26/07, 4:28 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Had a draw inspection the other day and for the first time in 3 years not only was the pull down fire rated but it was installed with nails. On site was a female framing crew that was rocking, doh't know if that has anything to do wtih or not.
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 7/27/07, 11:10 PM
Here's today's note the craftsmanship of the joist hanger installation for the stair rough in that has to be by the book, NOT and I guess we'll have to print all instruction labels bilingual from now on. The screw location looks intentional to me.
The vast majority of female construction workers I've met took painstaking pride in their work.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 7/27/07, 11:30 PM
Bruce Thompson's Avatar
Bruce Thompson Bruce Thompson is offline
That picture with the screw in the label is great!!! Classic
Necesita clavos aqui, entiendo?
Bruce Thompson
Professional Inspector, Lic. #9199
Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area.
www.TylerHomeInspector.com
NACHI 06081394
Old 7/27/07, 11:32 PM
nwagner's Avatar
Thanks for the great pointers!
LOL, I get a kick out of those blatantly ignored warnings, especially the one that has the screw drilled through it.
Question about improper installation cbell1 Exterior Inspections 3 10/24/07 10:13 PM
Opinions--Interior Staircase jjonas Interior Inspections 5 9/1/07 1:36 AM
Bonding wire installation requirements ?? rnewman1 Electrical Inspections 7 7/31/06 3:31 PM
How to pull out the "Stop Tube" (Moen 1225 cartridge) efang622 Plumbing Inspections 9 5/15/06 1:05 PM
Window installation jmichalski Exterior Inspections 17 1/24/06 10:42 PM
