Go Back   InterNACHI Message Board > Specific Inspection Topics > Interior
Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera.
Old 1/20/09, 2:54 PM
Buck Hartley, CMI Buck Hartley, CMI is offline
Default PVC vent for clothes dryer
What is your opinion of a PVC vent for a clothes dryer. This is first time that I have seen this. The large PVC pipe in the photo is the dryer vent.
Thanks! For your input in advance.
Old 1/20/09, 3:11 PM
Default Re: PVC vent for clothes dryer
PVC Ducting
While PVC tubing looks like it would be ideal for dryer venting being rigid and perfectly smooth, numerous technicians report that some sort of static effect seems to take place during use which causes lint to adhere to it, eventually leading to blockages. It may be best to avoid this material for this application if you can use rigid metal ducting instead.
also-
http://www.nachi.org/forum/f18/safety-issues-2436/
Larry Kage
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
My .02 cents.
I dont see a problem with the PVC itself, however, it is 3" not 4" like most dryer vents. Thats allot of tape to make the two fit.
Old 1/20/09, 3:12 PM
Dang your fast Larry.
Old 1/20/09, 3:15 PM
Joe Funderburk, CMI's Avatar
"IRC M1502.5 Duct construction. Exhaust ducts shall be constructed
of minimum 0.016-inch-thick (0.4 mm) rigid metal
ducts, having smooth interior surfaces with joints running in
the direction of air flow. Exhaust ducts shall not be connected
with sheet-metal screws or fastening means which extend into
the duct."
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 1/20/09, 5:25 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you want a real life example,think about this one.
Have you ever seen a Furnace use cat 40 other than cat 4 high efficiency model?
Now ask your self why.
You then have your answer. Make sense?
Old 1/20/09, 5:55 PM
Jeffrey R. Pope's Avatar
I don't understand Bob. Would you mind expanding on what you're trying to say?
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/20/09, 5:59 PM
relliott's Avatar
Plastic is not made for that kind of heat Jeff.
It may not burn ,but it goes soft and causes blockage.
You could have tried an answer.
Question with a question darn you
Old 1/20/09, 6:03 PM
I stand corrected.
Ty Bob
Old 1/20/09, 6:26 PM
relliott's Avatar
Originally Posted by mroberson View Post
I stand corrected.
Ty Bob
I was checking out a ICC forum a little while ago and some feel it is ok undera slab, but if the temp is high enough it can turn to a highly pliable plastic state and collapse.
Lint stops blowing through , backs up and then the lint turns into a fire hazard.
Of course the easy button says ,it is against code.
Old 1/20/09, 8:49 PM
Besides the fact, that using PVC pipe for Dryer Exhausts is against all Standards and Specifications, let us not forget that Code that prevails in this matter.; The Manufacturers Recommended Installations.
Hope this helps.
Marcel
Cyr Home and Commercial Property Inspections
IAC2 Certified
NACHI04070211
http://co.nachi.org/inachiawards
Commercial Builder
CertainTeed
Master Shingle Applicator
Shingle Technology
Ouellet Associaties Inc.
http://www.oaconstruction.com/
Old 1/20/09, 9:02 PM
There is alot information on the NET about this subject.
Thanks! for all the replys. I always learn something on this board.
Old 1/20/09, 10:40 PM
Paul Pendley Paul Pendley is offline
I guess you cant get much more clearer than that photo.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 1/21/09, 12:33 AM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
http://www.ul.com/consumers/dryers.html
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Dryer Vent Repair Philadelphia nhagarty Ancillary Services & Additional Topics 0 1/12/09 10:22 PM
Dryer Vent Repair Montgomery County nhagarty Ancillary Services & Additional Topics 0 1/12/09 10:22 PM
Dryer Vent Repair Chester County nhagarty Ancillary Services & Additional Topics 0 1/12/09 10:21 PM
Dryer Vent Repair Delaware County nhagarty Ancillary Services & Additional Topics 0 1/12/09 10:20 PM
Dryer Vent Cleaning Philadelphia PA nhagarty Ancillary Services & Additional Topics 0 1/11/09 1:24 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
