Old 12/16/06, 3:51 PM
Paul W. Abernathy's Avatar
Default QOD- Give this one a TRY...
Hey Guys,
Nice QOD for this area......enjoy !
Q # 1 = What of the following is NOT a or part of the requirement for the door between garages and houses?
A) 1 3/8 In. Thick
B) Solid Wood
C) 1- HR Rating
D.) Self Closing
Notice - Based on the 2003 IRC & 1997 UBC( to keep the answers uniformed ) I am fully clear different areas may have different thoughts...lets stick to the 2003 IRC and 1997 UBC right now.
One is obvious......do YOU know which it is.....Feel free to POST !
Paul W. Abernathy,CMI,CPI,CME
Old 12/16/06, 4:08 PM
Default Re: QOD- Give this one a TRY...
Ok....Heck I might get it wrong myself...someone answer the freakin thing...lol
Old 12/16/06, 4:35 PM
Ok....no replies......
1997 UBC -
A self-closing, tight fitting solid-wood door 1
3/8" thick or a self-closing, tight-fitting door having a fire-protection rating of not less than 20 minutes, will be permitted in lieu of a one-hour fire door assemble. Doors shall be provided with gasket so installed as toprovide a seal where the door meets the stop on both sides and across the top.Fire dampers are not required in air ducts provided ducts within garage are
2003 IRC -
Opening Protection. Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openins between the garage and residence shall be equipped with solid doors not les than 1 3/8" inches in thickness, solid or honey comb steel doors not les than 1 3/8" inches tich, or 20- minute fire rated doors.
Ok....confession........that is why I posted both references....so in the question...NOW which one would apply as the obvious one that is a bit OFF if you combined the BOTH references.
Old 12/16/06, 5:24 PM
wsiegel wsiegel is offline
1 hour fire rated door
Old 12/16/06, 7:45 PM
Jeffrey R. Pope's Avatar
Yep. That's the one. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/16/06, 9:09 PM
bandag bandag is offline
Please Note: bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
The 1 hr. fire rated was off, 20 minute min. on both, no self closing required in IRC 309.1
Old 12/16/06, 9:19 PM
Did any think of the fact that a 1 hour rated door needs a frame that is rated for 45 minutes and I doubt that a wood frame would meet that. So I guess we are back to a 20 minute rating at best. As far as I know, there is no rating on wood frames. Correct me if I am wrong.!
Marcel
Old 12/16/06, 10:11 PM
Check here, Marcel:
http://www.maiman.com/Products/Jambs.asp
Larry Kage, CMI
231 929 3525
Old 12/17/06, 6:18 PM
it is in the UBC.......the question gives a few from BOTH references...to show only (1) is obvious
1997 UBC -
Old 12/17/06, 8:52 PM
Originally Posted by lkage
Thanks Larry;
I didn't realize they had wood frames fire rated.
Marcel
Old 12/18/06, 8:19 AM
Originally Posted by mcyr
Thanks Larry;
Marcel
You're welcome...I'm pleased I could return some of your fine assistance.
Larry Kage, CMI
231 929 3525
Old 12/18/06, 8:31 AM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
not to drift but does anyone know what the rating for a pull down stair unit is?
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 12/18/06, 9:54 AM
Bruce,
I am sure I will be flamed for it...but I will give you what I know in MY mind to be true..
1.) If the space over the garage is not seperated from the rest of the house it will require a 1 hr rating. You can get ceiling pull downs in a 1 hr fire rating as that would need it IF the ceiling above is open into the other part of the dwelling.
2.) If you have a fire rated seperation between the normal dwelling part and the garage space then I would be suspect most will install a normal pull down door....however on the ones we install we cover them with 5/8" drywall.
Others may have more information for you......
Free Inspect & Protect books for Chapter heads to give away as door prizes. gromicko Miscellaneous Discussion for Inspectors 2 1/26/07 10:03 PM
Foundation QOD- Give them a SHOT ! pabernathy Structural Inspections 13 12/18/06 10:12 PM
Inspection photos, give to clients? sfalvey General Inspection Discussion 37 6/5/06 10:59 PM
