Old 3/13/07, 1:09 AM
waksell waksell is offline
Default Question about pull down attic stairs
I understand that an attic access in a garage needs to be fire rated, usually 5/8" drywall.
But what about pull down attic stairs?
I've only seen the ones with plywood on the bottom.
Do they make them with a fire rated bottom?
Are the plywood ones only for interior use? (not the garage)
What do you guys say, or recommend, when you come across this?
Is there an acceptable fix for this situation?
I hate to criticize something without offering a recommendation.
Old 3/13/07, 1:16 AM
Brian E. Kelly's Avatar
Default Re: Question about pull down attic stairs
Pull down stairs are generally not fire rated and should be called out.
Many times where there is a warning where the stairs attach to use NAILS there are no nails.
Old 3/13/07, 1:24 AM
Thanks Brian. Is there any other other material, other than 5/8" drywall, that is fire rated?
Old 3/13/07, 1:29 AM
Sheet metal.
Old 3/13/07, 1:41 AM
Needs nails here.
Old 3/13/07, 1:57 AM
Charley L. Bottger's Avatar
Originally Posted by bkelly2
Sheet metal.
Brian have you not seen sheet metal burn I set a large air handler on fire once with a torch, the galvanized made the darnest bunch of white smoke you ever dreamed of evacuated the whole research and development building I think that effected my next pay raise
</IMG></IMG></IMG>
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 3/13/07, 8:43 PM
rwhite6 rwhite6 is offline
Georgia has added this exception to the section in the IRC pertaining to Garage separation (R309.2):
Exception #2:
A disappearing/pull-down stairway with minimum 3/8-inch (9.53 mm) (nominal) fire-retardant-treated structural panel is deemed to meet the 20-minute thermal barrier test based on ASTM E 119, Test Methods for Fire Tests of Building Construction and Materials, or deemed to have the fire resistance of or equivalent to ½-inch (12.7 mm) gypsum wall board.
(Effective January 1, 2007)
I found a company (in Mississipi or Alabama, I believe) in a web search last year that claims to make pull-downs that meet the referenced thermal barrier test. I don't remember the name, but I'll try to find it again.
Bob White
www.abide-able.com
Old 3/13/07, 10:36 PM
mthomas2 mthomas2 is offline
Saw one of these once - *very* nice:
http://tinyurl.com/yov9qt
http://www.rainbowatticstair.com/att...re-ladder.cfm#
Old 3/13/07, 10:57 PM
gbeaumont's Avatar
AW, come on Brian be fair, at least that label is properly affixed
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 3/14/07, 9:31 AM
ntoll's Avatar
ntoll ntoll is offline
Please Note: ntoll is a non-member guest and is in no way affiliated with InterNACHI or its members.
Gerry
Maybe not. There is only one screw securing the label and it it crooked.
Also, the screw is slightly stripped. Might make it difficult to remove the label for repairs.
Old 3/15/07, 9:04 AM
Barry Adair's Avatar
Memphis Folding Stairs, Inc. used to sell a unit with Fire Retardant applied to the 1/4" plywood door I contacted them for documentation and they never responded.
X indicates recommended location of nails or screws
USE ONLY
Note: Due to different display options and printer setups, actual size may not be represented
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 3/15/07, 5:27 PM
Thanks, Barry.
Memphis is the company I was thinking about.
Your photo jarred my memory. I remember it from a thread on another forum from last year.
Memphis still offers the Fire Guard retardent treated units on four of their five pull-down products.
The describe it thus:
FIREGARD OPTION
The fire retardant plywood door panel is chemically treated to provide slower ignition, low flame spread, lower smoke production, and has self extinguishing features (burning ceases when ignition source is removed or exhausted.) Class A, or 1, pressure treated plywood is approved by building codes throughout the US for specific applications within fire resistant buildings as an equal alternative to non-combustible construction.
but they don't give any more information anywhere on their site.
Bob White
www.abide-able.com
Old 3/15/07, 6:39 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Have only seen one so far. this house was a joy to inspect the builder was great too.
And yes it was put in with nails
question-pull-down-attic-stairs-jst_p1010075.jpg   question-pull-down-attic-stairs-jst_p1010074.jpg
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 3/15/07, 7:13 PM
David P. Valley's Avatar
If the garage pull-down stairs are not fire rated then you can always recommended this fire rated pull-down.
Old 3/15/07, 8:11 PM
Nice Dave and I agree that is what should be installed, but how many developers and Contractors or Homeowners will go for that expense?
They will do like all of them and buy the $125 one from Home Depot.
And the AHJ will not even notice it. ha. ha.
It will give us something to write in our reports though, right?
Marcel
</IMG></IMG>
code for minimum floor space at top of stairs? areid Miscellaneous Discussion for Inspectors 12 4/16/07 10:39 AM
Attic Pull Down Stairs charper Structural Inspections 7 2/21/07 4:31 PM
Attic ventilation question pdoane Interior Inspections 8 8/27/06 3:22 PM
