Question:
I know pull-down attic stairs found in the garage need to be fire resistent, but what about when you find one in a bedroom or storage room . . . does the cover still need to be fire-resistant? and if so, 20 minutes? The pull down stairs assembly is made almost entirely of wood. Thanks in advance for your response. Mike Chris, Santa Clara, Utah
NACHI: #05051385 HouseNspect@gmail.com www.housenspect.com activerain "A man's home is his castle . . . until the queen arrives." |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Only the garage needs a fire barrier (e.g. special drywall, special door) due to the higher risk of a fire in the garage.
Thanks Ralph, that's what I thought, just wanted to check with another, these old brain cells seem to get out of order every now and then.
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 7:31 AM |
| code for minimum floor space at top of stairs? | areid | Miscellaneous Discussion for Inspectors | 12 | 4/16/07 10:39 AM |
| Attic Pull Down Stairs | charper | Structural Inspections | 7 | 2/21/07 4:31 PM |
