Guys;
Need a quick answer and I am drawing a blank. What is the name of the plaster that protrudes between the lathe in a plaster and lathe wall? Those little puch through parts of the plaster that holds the plaster to wooden lathe. Brain flatulance today. Sorry. First one to answer, fast, e-mail me and I will send you a copy of my new (and funny) presentation PowerPoint. Thanks; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
The Key
scratch coat
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
how about "keying"
the scratch coat forms the "key"
bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
a) "the key"
b) "the scratchcoat" c) "keying" d) "scratchcoat forms the key" e) all of the above |
Bruse King was first with an e-mail, but if you other guys want the presentation (and have the ability, through your ISP to recieve large files) just fire me an e-mail and I will send it to you.
It is funny, but also educational. It is called "Structure - A Case Study". Thanks again. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Three coat plaster over wood or metal lathe is as follows:
Scratch coat Brown coat Finish coat. As a mason, I've actually installed the stuff when performing disaster restoration work on old Richmond, VA row houses. (It ain't fun) "This above all: to thine own self be true." - William Shakespeare Last edited by mbryan; 2/23/06 at 4:56 PM.. |
Thanks Will, I look forward to watching the presentation.
Let me know what you think, Bruce. I can always use feed back.
BTW: I, along with Ken Demski and Russ Myers, am writing a new course on structure. Title: Everything I know about structure, I learned in Kindergarten. Use analogies from kids playing with blocks to teach structure principles like loads, stress, compression, etc. Have a heck of a section on crack analysis. Working with a PhD in Engineering from Northwestern University. Up to 325 PowerPoint slides. Once we get it state approved, it will be available to all NACHI Chapters. Hope this helps. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
sorry couldnt resist this one.....Just say no to crack!
| I need an answer...Quick | dvalley | Electrical Inspections | 10 | 11/5/07 10:54 AM |
| Real Quick Help Needed | jbowman | Electrical Inspections | 12 | 11/18/06 11:16 AM |
| Volunteer home inspectors needed to help elderly/disabled. | gromicko | Miscellaneous Discussion for Inspectors | 1 | 11/13/06 7:33 AM |
