Old 11/16/11, 8:37 AM
Raymond DeVaul Raymond DeVaul is offline
Please Note: Raymond DeVaul is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Radiant ceiling heat insulation
hi, I've got a house that has radiant ceiling heat. Last year quite a large ice dam had built up and ripped the gutters off each side of the house. Although the constant change in winter weather played a role, Im sure the lack of insulation was also a factor. Is there a "best" way to insulate an attic with the radiant ceiling heat? I would like to just use blown in insulation. If possible am I able to blow the insulation in right on top of the ceiling heaters? Thank you in advance.
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/16/11, 8:54 AM
Default Re: Radiant ceiling heat insulation
http://www.nachi.org/forum/f21/radiant-heating-ceilings-48997/
Larry Kage, CMI
231 929 3525
Old 11/16/11, 6:52 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
Are you talking electric ceiling heat or hot water?
If indeed you are talking about ceiling electrical panels you are not benefiting by using the electric radiant ceiling heat. You should disconnect the units and install wall hanging electric heaters, the price of electrical does not warrant keeping your ceiling warm period. You then can insulate your ceiling to more than R50 with no problems of ice dams or lost heat from the tranfer.
http://www.nachi.org/forum/f48/radia...23/index2.html
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Ceiling Radiant Heat Steve Lafond Interior Inspections 8 2/28/12 8:26 AM
Radiated Heat dhuxted Interior Inspections 31 10/3/10 1:49 PM
Radiant heating in ceilings bleibgott Ancillary Inspection Services & Additional Topics 13 4/26/10 9:27 PM
Radiant Ceiling Heat gluck Canadian Inspectors 17 3/27/08 10:43 AM
Radiant Heat Transfer rmyers1 Structural Inspections 0 5/31/06 11:21 PM
