Old 10/16/13, 6:28 PM
Sean Fogarty's Avatar
Default Railing spans
Anyone know where I can find max spans for deck railings and hand rails, in regards to spacing of support posts? Cant seem to find it in the IRC.
Fogarty Inspection Services Group of Palm Bay FL
Florida Licensed Home Inspector #8351
Certified Master Inspector
Home inspections, Commercial Inspections, Thermal Imaging, Wind Mitigation and Insurance Inspections for Palm Bay, Melbourne, Cocoa, Titusville, Vero Beach and all the surrounding areas.
321-506-5125
[email protected]
www.homeinspectorpalmbay.com
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/16/13, 6:32 PM
Michael Larson's Avatar
Default Re: Railing spans
4" guard rails
4-3/8" stair rails
6" step triangle area
http://www.nachi.org/deck-inspections.htm
As a Professional Home Inspector, I support the privacy of my clients.
For more information click Trustyourinspector.ORG
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 10/16/13, 6:43 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
I don't believe there is such a requirement.
The only consideration is the strength of the rails. They must be adequate to resist a lateral load of (?)200 lbs(?). If you can span 40 feet and still adequately resist the lateral load, no additional support is required.
(?)I'm on my phone and didn't verify the load requirement(?)
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/16/13, 6:46 PM
Sorry Sean. I misread your intent.
Michael Larson
Hudson, WI
Call me
Old 10/16/13, 6:47 PM
Originally Posted by mlarson View Post
4" guard rails
4-3/8" stair rails
Not ballusters, Actual support posts, meaning haw far can I run a hand rail before I need another support post.
321-506-5125
[email protected]
Old 10/16/13, 6:48 PM
No spec. Must withstand 200 lbs. lateral force.
I lean into them and make a judgment call.
Michael Larson
Hudson, WI
Call me
Old 10/16/13, 6:50 PM
Do you weigh more than 200 lbs Mike????
321-506-5125
[email protected]
Old 10/16/13, 6:51 PM
Not a problem.
If you are a fly weight Sean you may have to take a run at it and hope.
Michael Larson
Hudson, WI
Call me
Old 10/16/13, 6:53 PM
Thanks!
321-506-5125
[email protected]
Old 10/16/13, 7:48 PM
Troy N. Pappas's Avatar
Troy N. Pappas Troy N. Pappas is offline
I thought it was 6ft for guardrails at decks.
Troy Pappas Virginia Beach Home Inspector
Professional home inspector serving Virginia Beach, Norfolk, Suffolk, Portsmouth, and Chesapeake 757-418-0944
Old 10/16/13, 8:10 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
As Jeff mentioned, as long as it withstands or meets the 200# requirement, you should be all set to go 6'-8'.
My experience dictates that most composite rail manufacturers, design their rails to span 8' on the guardrails and 6' on the stair rails. But that all is dependant on the post anchorage to the deck design.
Hand rail brackets are usually spaced at 48"-64" apart as a standard that maybe variable on the design of the hand rail.
Cyr Home & Commercial Property Inspections
Inachi Award Winner 2009
Old 10/16/13, 8:16 PM
kwood kwood is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
According to the 2009 Deck building Codes you are right Troy.
If you use the IRC it has the 200lbs force allowance.
InterNachi also recommends 6ft and every 5 ft for the stairs.
According to the 2009 Deck Building guide they are called Guard Posts.
Old 10/16/13, 8:46 PM
Bradley K. Toye Bradley K. Toye is offline
Looks like code requires 200 lbs lateral force. To achieve this, it is recommended that support posts be spaced at max. 6' oc.
From Deck.com
Deck Railing Codes
All decks higher than 30" above grade must have a guardrail. If you choose to install a guardrail on a deck lower than 30" you must still meet code requirements. Decks attached to single family detached homes are regulated under the rules of the International Residential Code (IRC). The IRC requires guardrails to be at lest 36" in height measured from the deck surface to the top of the rail. Commercial decks attached to multifamily buildings such as apartment buildings or businesses are regulated under the International Building Code (IBC). The IBC requires 42" high guardrails. In either case you are allowed to build taller guardrails as long as they conform to all other requirements stated in the code.
A variety of styles are allowed as long as the interior sections of the rail don’t possess any openings large enough to pass a 4” diameter sphere through. In the case of guardrails for stairs there is an exception that allows up to a 6”diameter sphere through the triangle opening formed by the stair riser, stair tread, and bottom rail. The guardrails must be strong enough to withstand a concentrated 200 lb force anywhere along the top of the rail. To achieve this, you should space rail posts no greater than 6' apart.
Handrails are required for stairs and must meet standards as specified by R311.5.6.3 in the IRC code. The top edge of the handrail must be placed between 34” and 38” above the nosing of the stair treads. Handrail ends must be returned and terminated at rail posts. The handgrips must allow a minimum of 1-1/2” space between the handrail and the guardrail or wall. A variety of gripping surfaces may be acceptable but must meet requirements for gripping surface. Flat 2x4 and 2x6 handrails are not acceptable. A circular cross section of a handrail must have an outside diameter of between 1-1/4” and 2”.
Engineered railing systems must be tested to meet IRC and IBC building codes. The tests include:
Infill Load Test: The strength of the balusters are tested so that a 1 square foot area must resist 125 lbs of force.
Uniform Load Test: The top rail must be able to sustain 125 lbs of force applied horizontally or vertically.
Concentrated Load Test: The top rail must be capable of holding a point load of 200 lbs of force applied to the mid span, on the side of a post, and on top of a post.
A safety factor of 2.5 is usually added to the testing.
These tests are performed by an accredited third party testing agency.
Old 10/16/13, 9:03 PM
Shouldn't always believe the first thing you read if you have never built it.
https://www.decks.com/deckbuilding/Deck_Railing_Codes
Most composit kits are sold in 6' and 8' sections for guard rails.
http://www.decks.com/deckbuilding/Composite_Deck_Rails
This is a composite guard rail system with steel balusters. Most composite railings are sold in 6' and 8' kits. 4x4 posts, post sleeves, post caps, and post base trim are sold separately.
You going to tell me after 40+ years that I have been exceeding the 6' requirement?
Old 10/16/13, 9:27 PM
Not quite sure what you are saying here, but I can assure you that I have built 100's of decks with railings. Didn't really know about the 200 lb requirement until a few years ago, and it never came up on a building inspection either. I do reinforce the posts pretty good and usually space them between 5' and 6' depending on uniformity.
The reference from Decks.com refers to site-built guard rails from scratch, and appears to be taken directly from IRC. The kits are engineered to code (I presume), and still comply if built to manufacturer recommendations.
Deck stairs and railing movement mglowczynski Exterior Inspections 8 7/25/13 8:12 AM
Stair Railing Horizontal boards. sfogarty Interior Inspections 9 9/5/12 9:21 AM
Child slips through railing, falls, dies Ted Cushman General Inspection Discussion 52 8/8/11 12:36 AM
