Question, what is the standard clearance for range top to microwave/fan bottom. The owner replaced the exhaust fan with a microwave fan unit and the clearance was such as you had to bend over to see range dials. I told the buyer it’s a good thing your short and don’t use any large pots or fry anything on back burner.
I checked in IRC and online for more info but came up dry. The range documentation was not available to see recommended clearance. |
The manufacturer has specifications on the height above a range if the microwave is equipped with an exhaust fan. Otherwise, it can be at the same height as the bottom of the upper cabinets. This is typically 54" above the finished floor. Hope this helps.
Sincerely, Charles M. Bellefontaine Bellman Group, Inc. 877-316-0600 Extension #802 Click Here to Join our Email Newsletter Get Illinois Home Inspector Pre-License Education and Continuing Education at www.bellmangroup.com |
apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have seen manufacturers with as little as 13" clearance from stove top. That would never work in my house, I need more room for my pots and pans.
Anatol |
I'm just going from memory here, when I installed mine a few years ago, it (the manufacture) called for 20" from the burners to the bottom of the built-in...............Just went and looked up the stats in the GE manual. The electric range manual states, 30" to unprotected wood...24" if protected with flame retardant millboard and metal covering.
The GE microwave manual states 30" to the bottom of the cupboard that you are attaching the TOP of the microwave to. On my unit that would bring the bottom of the microwave about 14" above the stove....thats low! You would hardly get a canner pot under that! My cupboard is about 34" above the stove top, which puts the bottom of the microwave at about 18" clearance. Maybe you can find out what the exact specs are by searching the web for your specific make/model. GE's is www.GEappliances.ca Darrell Hadler CMI Five Star Home Inspections Medicine Hat, AB. Canada NACHI# 04111082 Cell phone# (403)502-3593 Inspected once . . . inspected right! (website) http://inspectorpages.com/dhadler
From the 2003 IRC
SECTION M1901 RANGES AND OVENS M1901.1 Clearances. Freestanding or built-in ranges shall have a vertical clearance above the cooking top of not less than 30 inches (762 mm) to unprotected combustible material. Reduced clearances are permitted in accordance with the listing and labeling of the range hoods or appliances. M1901.2 Cooking appliances. Household cooking appliances shall be listed and labeled and shall be installed in accordance with the manufacturer’s installation instructions. The installation shall not interfere with combustion air or accessibility for operation and servicing. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org Last edited by jsieg; 12/27/06 at 7:35 PM.. |
Department of Design, Housing and Apparel, University of Minnesota, St. Paul MN 55108-1011
Two studies were conducted to determine recommendations for placement of a microwave cooking appliance in residential kitchens. In the first study, 30 subjects completed tasks using microwave ovens located at heights typically used in kitchens and evaluated the safety and convenience of the tasks on a five-point rating scale. The ratings at the varied microwave oven heights differed signify cantly for both safety and convenience evaluations. In the second study, 24 par participants prepared a dinner meal. Data collected included the number, purpose, and sequence of trips between the work centers during the meal preparation. The utilization of a microwave oven did significantly change work-center relationships. Based on these studies, for safe use, the microwave oven should be located so that the interior food shelf or rack is no higher than the user's shoulder; 58"-60", for most convenient use, the interior shelf or rack should be located from between 2 in. (5 cm) below the elbow to 10 in. (25 cm) above the elbow. The microwave oven center should be placed so that it is close to the mix center. When the microwave oven and range are combined in one center, this center should also be convenient to the sink center. From this survey, one could say that the stove height is 36" 18" to the bottom of the upper cabinets, and that would place the bottom of the microwave oven at about 24" above the stove. I Would imagine that 58" to the bottom would be adequate. Hope this helps. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
It also depends on if it gas or electric, if it's a gas range some of the new hot rod high BTU gas ranges have very specific requirements. I would always go with what the range manufacture recommends for clearance for the specific model of range. Also on these hot rod ranges the side clearances to combustibles, cabinets, are also very specific.
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
What, no pics??
Thanks guys, sometimes a simple question can be more involved than you think. I knew that 16" was far too close. This is a very common problem I've seen too many times. The cost to replace a cabinet that is too old to find a match and then move the exhaust pipe and mounting bracket up could be costly. I reccommend re-installing an exhaust fan and use a counter top micro unless they are willing to spend the money, or risk their safety.
Under 11 3/4" and the stainless steel micro handle was over 200°F or 93°C after just a few minutes SS handle absorbs heat quickly, be mindful and careful
ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 9/30/08 at 9:50 AM.. |
Barry, the second picture at 19" would be my preference too.
rrichards2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Good post Barry.
I am not a big fan of over the stove microwaves. The trade off to save a little counter space is not worth the risk of serious burn injuries. |
jwisecup is a non-member guest and is in no way affiliated with InterNACHI or its members.
I wish I would have thought about this before I bought the microwave to go over stove 2 months ago. I got it home and realized it would be too low (17 inches)unless I moved all the cabinets up.
So, its sitting in the garage taking up my work space. |
The ol' microwave sitting in the garage. Did you use to live in San Diego? NACHI 2005 U.S. Member of the Year
| Wood Cabinets over Range Top | Skip Erwin | Interior Inspections | 2 | 4/15/07 9:14 PM |
| Range hood | Ian Gills | Electrical Inspections | 3 | 2/2/07 9:14 AM |
| Range exhaust hood question | mmorgan | Interior Inspections | 24 | 4/20/06 10:50 PM |
| Siding to Ground Clearance | tneumann | Exterior Inspections | 14 | 2/9/06 12:48 AM |
