It is my understanding that the purpose of range exhaust hoods is to remove heat and moisture from the home.
In TRECs (Texas Real Estate Commision) SOP's we are required to call out the absence of a range hood or a range hood that does not exhaust outside of the home unless it is a recirculation type. Can someone please explain to me what good a recirculation type of range exhaust is when all it does is blow heat and moisture right back into the home? Thanks Mike Morgan Central Texas Home Inspections mike@centraltexashomeinspections.com www.centraltexashomeinspections.com |
Same reason people put black shingles on a house. It looks good. A ventless range hood usually has a thin charcole element filter that "semi" removes smoke. Other than that it does not do much but like you say circulate the hot, moist air back around the room. Most of them blow the offending air right back into your face if you are standing in front of the stove. My report forms has all this pre-printed on it and I explain the ventless hood to the client. Little else you can do.
Besides when the wife cooks Sunday brisket it is nice to still know that a week later. |
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
And if you don't clean the filter you can not only smell brisket but ham from easter 3 years ago...mmmmm ham
Look at this URL, you might find interesting to this topic.
http://www.ces.ncsu.edu/depts/fcs/pub/8(1)/parrott.html Hope this helps. Marcel |
Have you ever realy looked at a range hood? i mean from a functionality stand point. go in you kitchen and look at yours. ask you self, "what 2 burners do i use the most?" then look real good and ask "what are the only 2 burner actualy covered by the hood?" 99 out of 110 will answer "front 2" for the first question and "back 2" for the second question. so do you realy think it makes THAT much difference if it's vented out or recerculating? a pretty inificiant system if you ask me. but on the other hand, if it did cover all the burners, you'd smack you head on it EVERY time, unless you mount it up over your head.
If the home is cold, blowing the heat back into the house helps warm it up. Darn margaritas. NACHI 2005 U.S. Member of the Year
R Ray, I installed on last year that was in a house of many dollars, and installed in an island cook center. Press a button, and it would come out of the island countertop. It was connected to a 10 inch duct with an exterior wall fan. CFM's 380 cfm. Your eggs would probably slide from one side of the pan to the other.
Couldn't hit your head on this one, but might suck the Margarita out of your glass. ha. ha. Marcel </IMG> |
or Underhead, no bang my head, but no margaritas either. That's a tough one. Will require more research. Fortunately, I have a good research team consisting of me, Ms Margarita, Dr Cuervo, and Dr Vicodin. NACHI 2005 U.S. Member of the Year
That's funny R Ray. If you are going to have a few while your research team is doing the work, have one on me, what the hell your paying anyway. ha. ha.
Marcel |
Hmmmmmmmmmm.
Everyone wants to be on my research team or they simply want me to pay for their sins. Hmmmmmmmmmm. NACHI 2005 U.S. Member of the Year
rrichards2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Did not go for the cheapest I went for the quietest. It has six slots under the front and this causes a vornado effect . It does a great job on low speed removing all the steam from the front burners. I guess you get what you pay for. Roy sr |
| Complex challenge with bath exhaust fan - need help with solution! | Bill Featherstone | Electrical Inspections | 11 | 11/5/07 2:16 PM |
| Range hood | Ian Gills | Electrical Inspections | 3 | 2/2/07 9:14 AM |
| Range Hood Duct Length | DSuelflow | Inspecting HVAC Systems | 3 | 1/24/07 7:41 AM |
