| Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera. |
Someone please help me understand the logic of this recessed light label. To me it says, "Warning: Do not install this light surrounded by insulation. But if you do install it surrounded by insulation, remove this label."
Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Joe, would that not just mean if it is a rated IC enclosure, the label does not apply?
Only thing that makes sense to me. Marcel Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
If the fixture is rated for an IC application, why put a label on it to begin with?
Maybe, it is one less step for the Manufacturer to save money on training employees to tell the difference. ha. ha. Marcel Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
Translation:
"If you can read (english) and you can't read instructions (and don't know about installing can lights in ceilings with insulation and, therefore, have no business doing electrical) then, we, the manufacturers (or maybe just our chinese suppliers) don't want any part of the inevitable lawsuit that will occur when this house burns down, so, PLEASE, we ask you to remove all the evidence that points to us." Probably one of the most honest statements I have seen on a piece of equipment. Hope this helps. (I speak fluent weasle language Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
In an insulated ceiling, the light/can must be in an enclosure rated for this purpose, ie. a metal box specifically made for the light. When you remove the diffuser from the light and you see the box, you have a correct installation.
Brian Jones To all newcomers, "Ceade Mille Failte" (Gaelic for "A Hundred Thousand Welcomes") 'If we wait for the moment when everything, absolutely everything, is ready, we shall never begin.' - Ivan Turgenev, novelist, poet, playwright |
Many cans have a similar label, with the instruction to peel it off.
These cans can be used in IC or non-IC applications, depending on the lamp wattage, lamp type, and trim type. This is normally listed on another sticker inside the can, or on the manufacturer's literature. Certain lamp sizes and trim types can only be used on these cans in a non-IC application, since they make and trap too much heat. Other lamp and trim combinations are okay for an IC application, so you peel off the warning label in that case. Were there other labels on this can, with a chart that shows IC and non-IC lamps and trim part numbers? |
Silver cans are usually IC, white cans are usually non-IC
Some more good advice here: http://www.inspectionnews.net/home_i...an-lights.html B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 |
Here is how you tell the difference between IC and non-IC rate fixtures... it's easy http://www.peaktoprairie.com/?D=225
Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 |
Here is how you tell the difference between IC and non-IC rate fixtures... it's easy http://www.peaktoprairie.com/?D=225 scroll down.
I'll try to budget some time this weekend to put together a more comprehensive guide if you're interested? |
Both you, Marc, and Kenton typically have good information to share. ____________________________________________ "An Education, not just an Inspection" Larry Kage Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond. ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
I hope this will be helpful. Luminaires Marking Guide |
| "UFER" Ground? see last paragraph. | jtedesco1 | Electrical | 6 | 9/15/08 8:57 AM |
| End of the light bulb as we know it!! | mcyr | General Inspection Discussion | 3 | 12/19/07 4:42 PM |
| Loss of a good Sense | mcyr | Misc. Discussion | 1 | 6/25/07 4:17 PM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical | 9 | 4/18/07 8:22 PM |
