Anybody have any ideas how to remove an existing ceramic tile from under the refrigerator portion of the kitchen to salvage it and use in an area I removed a beam.
I'm doing some renovations on a rental house of mine and I cannot find a tile remotely close to the existing and I really don't want to replace entire portions of the interior flooring if I can help it. I chiseled the grout from four tiles under the refrigerator area but they are really stuck to the slab. Was wondering if I poured some type of acid or something in the voids where the grout was it might penetrate under the tiles and loosen one. Any ideas out there would be appreciated. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Dale, if it's just under the fridge, can you remove the whole section of floor including the sub-floor and re-lay it as one piece?
Just a thought without seeing a picture. |
cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
Try a heat gun ( a real one not hair dryer) ,,,,,but not to much keep working the temp UP.... try lifting ...no give more heat....try again....more heat. Its a long process since you don't want to crack the tile.
THERE is no acid that would work and not ruin your tile abandon that notion. Hope it helps Curt |
Your success will largely be determined by:
1. How large the tiles are 2. Your level of patientce I assume the tile is applied with a mastic backing. |
There used to be a 16"x8' wall from the ceiling going toward where a post was, I removed the 16" portion of the drop down wall from the ceiling and finished it so the rooms look more open.
![]() This was an old style back in the 70's I guess. The tile is 12x12 and they are stuck to that slab like no tomorrow...I tried everything I can think of to get one loose from under the refrigerator area. It won't be a problem to remove this one, I want it to break..... ![]() Chiseling sideways under it with a wide putty knife etc, to no avail. Maybe I'll try just pouring water in the voids where the grout was and hope the versabond/thinset or what ever they used to attach the tiles will come loose eventually. Thanks for the ideas. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Houston, we have a problem.
Dale, All I can think of is getting a long hacksaw blade mounted in a sawzall under and edge and work it across. You'll probably have to destroy a tile under the fridge to get it started. Practice the technique on the tile you want to remove. |
Dale,
When I had to rip up the tile from my entry way I got a 4-6 inch wide putty knife that had the threads on the end and attached it to a broom handle. That allowed me to have a few feet of leverage. Then I would slide the knife under the tile fast and hard. Once you finally get under a tile the first tile it goes much faster. I did notice that nearest the entry way where there was probably more moisture that the tiles came up easier. Maybe you can combine this with the heat gun/ chiseling the grout. Depending on how strong the tile is you might be able to tap it with a mallet as well to loosen it. I did that for awhile but cracked one tile hitting too hard and had to lighten up. 2008 InterNACHI Member and Innovator of the Year HOME INSPECTOR PRO HOME INSPECTION SOFTWARE NOW ONLY $499 ($15O OFF!!) Easy to use, customizable Home Inspector Software that runs on Windows, Mac, Android & Linux InterNACHI members receive 3 months of FREE home inspector website hosting List yourself in our Home Inspector Directory Free Watch our NACHI.TV Software & Search Engine Optimization videos! Help@HomeInspectorPro.com |
Thanks also Dominic. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Regards Gerry (the tennants friend) Beaumont "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 Last edited by gbeaumont; 10/18/07 at 11:29 PM.. |
Dale,
Milwaukee makes a masonry blade! These folks probably have your solution if Mike's suggeation doesn't work for your situation. helps if i paste the link http://www.thefloorpro.com/ Can't be a slumlord if you're matching tiles Oh, yeah their opinion of us is none of our damn business ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 10/18/07 at 11:33 PM.. |
Dale
Save the tiles under the fridge, leave them alone Brother!! You will most likely break all of them in attempting to remove them. I suggest that you create a pattern around the damaged tile. For example take the entire row out wall to wall and replace with something that is the same size but a little darker [or lighter] in color or take four tiles out including damaged tile and replace with new.Just be creative in the design. Remember to use the same size tile it will make your job easier. You might consider changing the color of the grout for the new tiles. People will think it was done by design! Not by necessity. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Another tile trick that works well is if you have a burn or Damage in kitchen counter .
Take a router and cut out the burn, diamond shape size of a tile . In lay the tile flush with the counter. People will think it is done on Purpose as a place to cut vegtables ,Works well looks good and you have saved a counter. ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I agree with Mario. Just change the design a little bit and remove and lay some new tiles.
Dale;
This is the only tool I know of that remarkably removes wall tile and floor tile grout where any attempt to salvage one tile might be possible. http://www.amazon.com/exec/obidos/AS...virginislandsi Once one tile is out of the way,you might be able to slide a 12" sawsall blade and cut the grout with a sawsall. (demo-blade) ![]() Ceramic has excellent compressive strength, but very poor tensile strength. Good luck. Marcel </IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Crack in tile floor? | pcloninger | Structural Inspections | 16 | 10/9/07 11:15 AM |
| Cracked flue tile | bknowlton | Inspecting HVAC Systems | 6 | 2/1/07 11:37 PM |
| Existing Home Sales Rise, Prices Fall | jburkeson1 | Miscellaneous Discussion for Inspectors | 0 | 11/28/06 2:46 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 4:52 AM |
| how to properly walk on a red tile roof ? | jimhanson | Exterior Inspections | 14 | 1/26/06 12:00 AM |
