60+ year old house. Original faced wall insulation.
Is this faced rock wool, or dirty glass? TIA, Tim |
| Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
By the colour and if original, I'd say "rock wool"
gray black
Rock Wool.... better than fiberglass.... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Thanks, guys. I thought so, but I've had no previous experience with it.
Cheers, Tim |
Learn how to do it the easy way.
Mineral wool/fiberglass type material. |
It's not Perlite.
Reasons? I tend to rate them as near equals for R value & installation except when it comes to cost......rockwool batts are more expensive than fiberglass batts here!! With higher R values (up to R50 in attics) in todays' much more efficient homes, the extra weight of the heavier blown rockwool on flat attic surfaces may require 5/8" drywall or thicker on the ceiling. For example: 1 brand of rock wool I looked up had a weight or 2.68 lbs/sq ft for R34. Cellulose is 1.23 lbs/sq ft for the same R value. |
pic in first post looks like perlite? ???? Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
all insulation is inadequate at best to the claimed (R) values.
Installation methods may vary...... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
The easy way to tell is to take a hot shower after you get home from the inspection. If you start itching so bad you can't write up the report, it was fiberglass.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Perhaps a "tongue-in-cheek" reference to this thread... http://www.nachi.org/forum/f11/attic-insulation-61322/
BTW... post #13 is still awaiting your reply. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Imagine the weight the the RW will have if it carries moisture. Q: What is rockwool? A: Rockwool is spun mineral wool fiber. Various "rock" components, with a heavy dose of silicon oxides are melted at high temperature and fibers are formed as molten material is passed by a series of "spinners." The finished product which is "bonded" via proprietary resins, is inert, meaning it has no cation exchange capacity. Approximately 97% v/v/ is air space. Bonded products (plugs, blocks and slabs) also contain a wetting agent, which may (absorbent) or may not (repellant) be present in granulated (also called flock) rockwool. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
| Attic Insulation | bhartley | General Inspection Discussion | 21 | 6/11/11 5:10 AM |
| September Inspection Slow Down?!?!?!.... | jwatts1 | Miscellaneous Discussion for Inspectors | 13 | 9/20/07 5:47 PM |
| Newbie here with a slab "standards" question | Robert Young, #3 | Structural Inspections | 17 | 4/10/07 10:48 AM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 5:25 PM |
