I looked in the Attic from the access in the Hallway. The Attic looked great with no signs of water penetration. But I did see light coming thru from a point the the Attic peak.
Would this be a concern? Roof looks good, Attic looks good. Is seeing light coming from a point in the Attic peak a problem? David An Ounce of prevention is better than a pound of cure :} |
| Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Maybe, maybe not. Depends.
Most likely from an older Ridge Vent. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
What would be an acceptable write up....that informs
the client and protects myself. David An Ounce of prevention is better than a pound of cure :} |
I see the light.
More info needed for a smarter response David. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
In this case, you may have left the job without all the facts. Can you post photos? Would it be possible for you to go back and check again? Hopefully it's a vacant house that you can go back to tomorrow am without anyone needing to know. Pete Campbell pete4545@comcast.net http://www.PortStLucieInspections.com http://www.ChooseGI.com http://ifwemissitwewillfixit.com Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida. |
If you do this; "that informs the client" it will automaticly cause this;
Do you have a couple of good pics of the inside and exterior of the ridge in the areas that you saw the light???
No pictures of the exterior of the roof. It was two story building and you could not see the top of the house. An Ounce of prevention is better than a pound of cure :} |
I looked through the attic access in the upstairs hallway.... An Ounce of prevention is better than a pound of cure :} |
The camera flash blocks out the light coming in the attic.
Thanks.... An Ounce of prevention is better than a pound of cure :} |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would be scared to put anything in the report about "seeing the light", if I didn't get in the attic to confirm where it's coming from. In a dark attic and properly vented (soffits,ridges,gables) you should see light.
Was attic access too dangerous?? |
If you could not personally access attic to get a positive view of where light maybe coming from it would be in your best interest to call it out and refer further evaluation.
Don't care about that. Post what you got, please. You'd be surprised what 'others' see in a pic. There may be tell tale signs leading to a possible answer for you.
| Light Switch Near Shower | vsantos | Electrical Inspections | 204 | 3/19/12 9:58 AM |
| Moisture issue in attic | jgromkoski | Interior Inspections | 9 | 6/11/09 9:46 PM |
| Home Warranty Attic Insulation Question | jhawes | Canadian Inspectors | 2 | 12/4/06 1:54 AM |
