Old 12/28/07, 4:40 PM
ekartal6 ekartal6 is offline
Please Note: ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Serious Decay
Any example of what elevated vegetation (bushes) packed firmly against the exterior and surrounded by a retaining wall might do after decades of saturation, pressure and freeze - thaw cycles.
Old 12/28/07, 4:53 PM
Michael Larson's Avatar
Default Re: Serious Decay
Erol,
What's the deal with the booster pump set up?
Old 12/28/07, 5:14 PM
Home at one time oil heated. I believe this to be the booster for the old furnace. For the last 50 years or so it's been steam heat.
Old 12/28/07, 5:24 PM
If the valve marked "Bypass?" is closed it would seem to be a system still in use.
Old 12/28/07, 5:38 PM
I don't know about the valve positioning, but the steam boiler is and has been supplying heat to the home's radiators for many years. The booster and oil tank were disclaimed from the inspection.
Old 12/28/07, 5:45 PM
Old oil furnace to the far right and steam boiler in the foreground. Asbestos and all.
Old 12/28/07, 10:43 PM
Dale Duffy's Avatar
Unreal...and here I thought I had a rough job....... ...with a couple stucco and roof issues.......
Old 12/28/07, 10:47 PM
Dale Duffy's Avatar
I would have to think you guys inspecting all that old crap up north would need to charge a minimum of $1,000.00 per inspection....compared to our slab on grade, stucco, tile roofed shacks in the southwest......
Damn it must take a long time to do those reports......
Old 12/28/07, 10:58 PM
My inspection fee was fair, but what's killing me on this one is the report time. Live and learn.
Old 12/30/07, 6:49 PM
William J. Decker's Avatar
Define "fair". Come on Erol, fess up!
I hope this helps, but it probably won't.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Can someone explain why wood in contact with concrete causes rot? gromicko Miscellaneous Discussion for Inspectors 46 1/16/11 11:15 PM
Attic Temperatures Can Pose Serious Risks jtedesco1 Interior Inspections 4 4/2/06 10:17 AM
