Old 9/26/07, 3:23 PM
Barry Adair's Avatar
Default How seriously do you inspect dryer vents?
Like me you may want to pay closer attention and have advisements for your clients
Hot link from Inspection News
http://www.setexasrecord.com/news/20...nt-caused-fire
http://www.cpsc.gov/CPSCPUB/PUBS/5022.html
http://www.dryerbox.com/convertions/...nical-Code.pdf
http://www.dryerbox.com/convertions/...ntial-Code.pdf
http://www.dryerbox.com/dryer_venting_guide.htm
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 9/26/07, 4:18 PM
rdawes's Avatar
rdawes rdawes is offline
Please Note: rdawes is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: How seriously do you inspect dryer vents?
Thanks Barry
Old 9/26/07, 5:28 PM
Good reminder...thanks, Barry.
Larry Kage, CMI
231 929 3525
Old 9/26/07, 5:59 PM
Bob Elliott's Avatar
Thank you Barry I put the CPSC diagram staight on my clip board.
I will be using it a lot.
Old 9/26/07, 6:39 PM
Standard blurb from my report:
Dryer exhaust ducts should be independent of all other systems, should convey the moisture to the outdoors, should terminate on the outside of the building in accordance with the manufacturer’s installation instructions and should be equipped with a back-draft damper.
Exhaust ducts should be constructed of rigid metal ducts, having smooth interior surfaces with joints running in the direction of air flow. Screens should not be installed at the duct termination. Exhaust ducts should not be connected with sheet-metal screws or any means which extend into the duct. (Screens and screws can trap lint.)
Exhaust duct terminations should be in accordance with the dryer manufacturer’s instructions.
www.appliance411.com/faq/dryer-vent-length.shtml
Old 9/27/07, 6:01 AM
Russel Ray's Avatar
I would use a personal story here, but, alas, it seems certain people would jump in and create a bashing thread, so I won't. I'll just copy the following story directly from the San Diego Union-Tribune (Sept. 14, 2007, p. B2):
Fire Watch
Residents extinguish fire caused by clogged dryer
NATIONAL CITY: A teenager and a senior citizen extinguished a house fire yesterday.
Jordy Vazquez, 14, first noticed the fire behind a dryer in the laundry room shortly after 9 a.m. in the house on E Avenue near 15th Street. He told his mother to get out and grabbed a small fire extinguisher.
Jordy's neighbor, Manuel Ramos, 75, grabbed a second extinguisher and then a third. All the extinguishers spurted only briefly.
The two then ran out the back door and grabbed a garden hose and together used it to douse the flames. They extinguished the fire just before firefigheters arrived at 9:19 a.m.
The fire caused about $5,000 damage in the laundry room and kitchen, said National City fire Batallion [sic] Chief Randall James.
He said lint clogging the dryer's vent caused the fire.-M.A. and K.K.
I save stories like that all the time so that when a Client or Realtor asks me, "What's the worst that could happen?" or "Yeah, but how often does that happen?" well, I think that ranks right up there. Personal stories put things in perspective for people whereas they don't always understand the technical jargon or the warnings themselves.
Also note that the three fire extinguishers "spurted only briefly," providing you with another opportunity to counsel your Clients about not only having fire extinguishers in the home, but having those extinguishers checked annually to make sure they work.
Old 9/27/07, 7:33 AM
Now that we are taking care of our clients and the rest of the world I'll ask all of you to inspect your own dryer vents and fire extinguishers ASAP.
You may be surprised what you find!
I found the 16 unmatched pairs of socks and 2 pair of underwear. TMI
and yes my exhaust tube and dampered vent did need a good cleaning.
BTW, thanks ML
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 9/27/07, 10:15 AM
Russel Ray's Avatar
Were all of them yours, or have my 8 missing ones taken up with 8 of yours?
Old 9/27/07, 12:10 PM
Charley L. Bottger's Avatar
504.3 Cleanout.
Each vertical riser shall be provided with a
means for cleanout.
This one of my pet peeves I have a lot of vert rise dryer vents in my area and have consulted with the AHJ as to their defination of cleanout. There answer was remove the dryer that is your axcess. Needless to say I am against any verticle rise vents I find them blocked all of the time.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 9/27/07, 12:18 PM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
Barry,
You have provided some VERY useful information.
THANK YOU!
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
Old 9/27/07, 12:21 PM
Roy D. Cooke, Sr's Avatar
BTW, thanks ML
Gee I alway though missing socks went the same place as the TV controles went .
I figured there was secret place out in the bush where they all hide .
.... Cookie
</IMG>
Dryer sheets potential hazard badair Miscellaneous Discussion for Inspectors 15 7/9/11 2:39 PM
Dryer vents through roofs jfunderburk Exterior Inspections 10 11/17/07 10:48 PM
What is a 'condenser' dryer ?? rcooke Canadian Inspectors 9 9/9/07 7:02 PM
dryer and bathroom vents aweston Miscellaneous Discussion for Inspectors 4 10/22/06 11:12 AM
Dryer lint filter senomoto Miscellaneous Discussion for Inspectors 6 5/14/06 10:01 AM
