Go Back   InterNACHI Message Board > Specific Inspection Topics > Interior
Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera.
Old 9/11/09, 9:43 AM
James Eubank's Avatar
James Eubank James Eubank is offline
Default shadow/staining - wall studs showing thru drywall
Walls had this shadow/staining outline of the vertical studs and header, only on the interior surfaces of the exterior walls. On some walls more obvious, on others less obvious. Wall surface was drywall with a thin texture (poorly applied). Studs were metal. See the attached photo. Anyone run across this before?
Accurate Independent Inspections
Home - Commercial - Environmental
Find an InterNACHI certified South Carolina Home Inspector (and anywhere else in North America)
Old 9/11/09, 10:05 AM
Richard A. Hetzel Richard A. Hetzel is online now
Default Re: shadow/staining - wall studs showing thru drywall
If the occupants were either heavy smokers, or used candles frequently, shadowing like that can happen. My guess is also that the metal studs transmit cold more effectively than wood studs, so at each stud, in cool weather, there would be a thin film of condensation, which would attract and hold airbound particles, creating what we see in the photograph, more so than would wood studs.
The remedy would have been to incorporate a layer of rigid insulation across the stud flanges directly behind the drywall.
Old 9/11/09, 11:19 AM
David P. Valley's Avatar
When your posting a question, there's no need of placing your question in various threads.
http://www.nachi.org/forum/f23/shado...drywall-43150/
http://www.nachi.org/forum/f18/shado...drywall-43159/
http://www.nachi.org/forum/f2/shadow...drywall-43160/
That's ridiculous.
shadow/staining of wall studs showing thru drywall jeubank Structural 7 9/11/09 11:48 AM
Toxic Drywall from China inxil InterNACHI Blog 13 3/13/09 12:14 PM
Moisture Management mcyr Exterior 15 9/8/08 1:11 PM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues 50 4/20/08 2:26 AM
Popcorn Ceiling prubenstein General Inspection Discussion 10 2/7/08 11:12 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
