Is there a required shower door size, i.e., minimum 24 inches wide?
No there isn't Peter, that I know of, or read in any code book..."nada".
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
True.....I do know some folks who would not fit through there even greased---
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
helps if they open outward, too
less than 20" on this one ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 6/2/09 at 12:55 AM.. |
Like a sauna, a shower door should open outward for safety reasons.
I guess you got in the shower to test this one... Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
I am a bean pole, so entry/exit was not a problem. Opens outward.
It's new construction, so I was concerned, and recommended review of the plans, etc, etc, etc. |
Richard M was close--there is no door minimum, but the maximum user size is directly proportional to the entry opening.
| No caulking at shower wall to pan seam? | hmiller | Interior Inspections | 11 | 2/9/09 7:40 PM |
| Low water usage shower head - squirts | lfoster | Plumbing Inspections | 4 | 6/2/07 12:40 PM |
| Weep Holes in Shower Stalls? | ebeahm1 | Miscellaneous Discussion for Inspectors | 9 | 3/31/06 1:10 PM |
