Rafael is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have a ? do all showers on older homes and two story homes
have shower pans or is it just the ones with tile on them . Thanks for your help |
Not sure I understand your question completely, but here goes anyway:
The molded stall showers do not have pans under them (you can install just a molded pan and still have tile walls). All second story stall showers will have a pan (unless the shower has been replaced with a molded pan). Some of the older stall showers that are recessed into the foundation do not have pans under them. All tile grout must be maintained and filled in when necessary, as water will find its way through. Some people will seal the grout to prevent water penetration. Hope this helps. |
By molded shower what exactly do you mean and yes that
did answer my ? , thanks |
| Low water usage shower head - squirts | lfoster | Plumbing Inspections | 4 | 6/2/07 1:40 PM |
| Shower stall light/fan on garage GFCI | lprinzi | Electrical Inspections | 3 | 10/31/06 5:13 PM |
| Bait, Bites and Shower Doors | tmantsch | Miscellaneous Discussion for Inspectors | 2 | 5/4/06 5:52 PM |
| Weep Holes in Shower Stalls? | ebeahm1 | Miscellaneous Discussion for Inspectors | 9 | 3/31/06 2:10 PM |
