I don't think so, but would a bathroom vent be allowed to be installed in a shower stall under any circumstances?
What do you mean? Is the vent terminated under the stall or just passing under it?
Since there is no electricity connected to the ceiling register itself, there is no safety risk in mounting it in a shower stall.
It is a bathroom exhaust vent with a fan motor.
It's OK. |
Thanks for the help, I just figured there could be potential for electric shock with the fan actually in the stall.
Are we sure? I don't think fans are rated for wet location installation. Covers are not sealed like wet light fixtures.
ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 9/30/08 at 3:09 PM.. |
If thee say fans ok what about this heater?
I wrote it up as a potential for electric shock and recommended it be moved outside the stall. I agree with Barry, the covers are not sealed. There was also a light in the stall that was a proper sealed fixture for a shower.
Ok, I've done a little more research on exhaust fan installations over shower enclosures, as I've never red-flagged this installation in the past. I should have stated that the fan must be UL rated for wet locations in order for it to be safely installed over shower enclosures. Most exhaust fan manufacturers do rate their fans to be installed over wet locations. I'll be revising my reporting methods for this particular install to read, "I recommend further evaluation of shower fan to determine if this exhaust fan is rated for wet locations". Here are additional links to this particular install... http://www.mikeholt.com/code_forum/s...ad.php?t=69803 http://www.hvi.org/displayindustryar...ticlenbr=26733 http://pages.quicksilver.net.nz/geoffm/fan_FAQ.htm http://www.amroyal.com/index.php?cmd=product&item=6385 http://www.keidel.com/design/select/vent-fans.htm http://www.airkinglimited.com/airkin...d&art_id=10#Q8 http://www.pegasusassociates.com/Bat...tFanP90064.jsp Last edited by dvalley; 2/6/07 at 4:56 AM.. |
David,
All you have to do is verify by label or stamp in the housing just like IC can lighting and make sure they cease operation when GFCI is tripped. No need for further evaluation unless this simple inspector evaluation fails. If so remove and replace. BTW as usual the informational links from you are great! Keep on keeping on. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Michelle B. Cooper is a non-member guest and is in no way affiliated with InterNACHI or its members.
The above link has changed to the PegasusAssociates.com website:
http://www.pegasusassociates.com/Bat...FanP90064.html |
Somehow I never thought about reaching up and grabbing the fan motor while taking a shower...
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Talk about kick starting your morning ....
Dick Dick Moran True Blue Home Inspections A Div of RAM2, LLC. Clarksville, MD 240-832-6838 MD Home Inspector License 29927 |
| exhaust fan over shower stall | dbook | Electrical Inspections | 5 | 4/24/07 4:40 PM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 9:17 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
| Shower stall light/fan on garage GFCI | lprinzi | Electrical Inspections | 3 | 10/31/06 4:13 PM |
