This was the only area...about 3 feet, where the wall meets the floor.
I didnt see any signs of water coming thru a near window, or ceiling. The water sprinklers did spray the outside wall in the area of concern on the inside of the house. Do you think the water could be wicking from the outside to the inside ? Its a slab foundation and the grounds were soaked from the water sprinklers be ran to frequently. ![]()
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
That is a very good possibility if you couldn't find any other signs.
What did the Outside wall look like and are they EIFS or Stucco.
Kisers Home Inspections http://www.inspectorpages.com/jkiser http://activerain.com/jimekiser http://www.kisershomeinspections.com |
Is that EIFS? Is the problem area under the window? There might be larger problems there if that's coming through the exterior finish and only showing up at the bottom. Just google EIFS damage and you'll be amazed how much damage can go on without visible signs. CYA
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Didn't look like a moisture stain to me. Looked more like crinkled paper. The molding wasn't stained at all. Did you test it with a moisture meter?
If you just pull lose the carpet and reset it after you are done. The carpet tack strips will give you some additional inforamtion (the degree of rust, staining, mold growth and outside dirt). Also you can try to track the leak down with a moisture meter.
thanks everybody
Agree, Looks like the drywall was bent during installation. Moisture reading would have been good. Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
| Nail pops at the base of vaulted ceiling-no roof leak | kshepard | Interior Inspections | 32 | 9/9/07 2:06 PM |
| More Moisture Discoveries | jpope | Interior Inspections | 30 | 8/16/07 1:54 AM |
