Old 12/9/07, 3:13 PM
Rafael Rafael is offline
Please Note: Rafael is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default sliding floor
Hi
I have a house 2 story and the drawers on one side of my house
slide open after closing them because the floor appears to be sloped.
Now i see nothing lookig up from downstairs that looks sloping but the floor
is sloped. what can this be maybe a sagging joist below, any help would be helpful.
Thanks
Old 12/9/07, 3:57 PM
Dale Duffy's Avatar
Default Re: sliding floor
Put a string line (use a nail at both sides of the wall for carpeting) (pulled very tight) from one wall to the other up 1" from the floor and measure down and you will find out how much difference there is. A simple solution to show if there is a warp.
Naturally a 4' Level will also work if you have a hard surface floor covering.
Also, are the legs on the dresser even?
Or you could get fancy and rent a Transit from Home Depot.
Old 12/9/07, 4:03 PM
Originally Posted by Rafael
Hi
Thanks
Would you be talking about furniture drawers or kitchen / vanity counter drawers?
One has wood slides and guides and the other is on rollers.
Also, first floor or second floor.?
Marcel
Old 12/9/07, 6:09 PM
upstairs and it is clothes drawer dresser
Old 12/9/07, 6:25 PM
My clothes dressers aren't that old and operate on wood slides.
So, if those don't stay closed and slide out by themselves,
Houston, we have a Problem.
Start in the basement if you have one and follow Dale's recommendation for starters. If not, that means you are on a slab and check the second floor framing bearing partitions or anything inbetween.
If on a crawl space, the problem most likely is from the girder supports and will be reflected up to the second floor.
Good luck.
Pictures would help.
Marcel
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 4:05 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Floor Box Recall bwiley Electrical Inspections 1 4/18/07 6:35 PM
A thread for serious discussion of Washington Senate bill 5778 dhelm Legislation, Licensing & Legal Issues for Inspectors 236 3/11/07 4:45 AM
