Who is responible for testing that a smoke detector works ?
My Home inspector school advised that we only note and inform that they are in the correct areas..... What is the a Home Inspectors responsibility in this area ? David |
It is prudent to note the number and location, but unwise to officially record their working status unless you intend to back that up if they fail during a fire.
I like to tell people that moving into a new home is a great time to replace smoke detectors to make sure they have all new and properly functioning units...a very small price for a very important item...jmo....jim
Agree, and I always put a statement in my reports, in BOLD and included in the Summary, that all fire detectors should be tested for proper operation immediately upon moving into home.
I note the locations, test the accessible units installed using the test button and recommend upgrading to current required locations when needed.
www.mauihomeinspections.com |
My General Comment...
Smoke Detectors - Detectors are noted as present but not sounded or inspected. - Recommend the installation of smoke detectors at each level and bedroom of the home. Placement should be in accordance with the manufacturer's recommendations. - Recommend the installation of Carbon Monoxide (CO) detectors in homes with Gas / Oil fired appliances. Placement should be in accordance with the manufacturer's recommendations. - Recommend the installation of Carbon Monoxide (CO) detectors in homes with attached Garages. Placement should be in accordance with the manufacturer's recommendations. - Recommend the replacement of smoke detectors at 10 year intervals per the manufacturer's recommendations. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
cmcdonald is a non-member guest and is in no way affiliated with InterNACHI or its members.
As a general rule, I also note if the location is at least 4 inches from the wall (for ceiling mounted detectors) and if the detector is at least 4 inches from the ceiling but not more than 12 inches from the ceiling for wall mounted detectors.
Just my two cents. |
Remember using the test button , only tests the energy source to the unit,and not function.
Check your state's SOP, if you are in a licensing state. Or, check the SOP of whatever certifying association you are a member of. Here's what NC says:
"C. Report on presence or absence of smoke detectors, and operate their test function, if accessible, except when detectors are part of a central system." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
"C. Report on presence or absence of smoke detectors, and operate their test function, if accessible, except when detectors are part of a central system."[/quote]
I accidentally tested a central system once so I was able to verify the response time of the police and fire department (which was actually pretty good. www.mauihomeinspections.com |
The smoke and co2 meters I bought for my house recommended they be replaced every 5 years. I'm not gonna guess how old detectors are in a house. I recommend they be replaced and the client checks with the local fire dept. for recommendations.
Mark Jones Allmark Home Inspection Services Inc. Serving all of Northern Illinois, Vernon Hills, Libertyville, Gurnee, Fox Lake, Round Lake Phone: 847 651 2053 E-Mail: AllmarkInspect@aol.com www.AllmarkHomeInspection.com |
I recommend they replace them, who knows what somebody might have done to one of them, or all of them, their cheap, and save lives, buy new ones. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I accidentally tested a central system once so I was able to verify the response time of the police and fire department (which was actually pretty good. www.mauihomeinspections.com[/quote] The fire department in my neck of the woods charges $800.00/truck for false alarms. I never test if there is an alarm system installed. I always suggest replacement as well. Cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
John Kogel www.allsafehome.ca |
| Smoke Detector placement | jwicklander | Electrical Inspections | 0 | 9/17/08 6:43 PM |
| Smoke and CO2 detectors | Michael Merino | General Inspection Discussion | 10 | 4/16/08 12:23 PM |
| Smoke alarm history | Marc D. Shunk | Electrical Inspections | 6 | 2/12/08 1:18 AM |
| WA State Legislative update | hmiller | Legislation, Licensing & Legal Issues for Inspectors | 153 | 5/4/07 11:55 PM |
| Answer to a common question about GFCI's | jtedesco1 | Electrical Inspections | 4 | 1/12/06 9:29 PM |
