Old 11/28/07, 1:36 PM
Robert A. Jack Robert A. Jack is offline
Default smoke or mold?
The home is a modular ranch built in 1985. Very heavy smokers. Well insulated attic with large gable and ridge vents and metal roof. The plywood sheething was black as shown. Could this be caused by excessive cigarette smoke? I question mold because of the good venting. The interior of the home was yellow with nicotine.
Old 11/28/07, 1:41 PM
Stephen W. Stanczyk's Avatar
Default Re: smoke or mold?
That appears to be a vent from a bathroom or kitchen fan. My bet is bathroom. It also appears to be newer. My guess is the bathroom fan emptied into the attic in this location for years until the last sale/inspection when this was installed. Pretty small picture to really get a good look.
Stephen Stanczyk
Old 11/28/07, 3:26 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Moist air from the bathroom exhaust vent and a hot roof (metal likely not insulated well from the decking) kinda 'scorched' it mayhap?
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 11/28/07, 4:43 PM
Bob Elliott's Avatar
used my magnifier and from what I see that is not from smoke.
My guess is the underlayment had a moisture problem from that vent not flashed properly.
Were u able to get a moisture reading?
Old 11/28/07, 9:37 PM
Hot air full of moisture hits the underside of the cold (Vermont) roof. Moisture condenses and wood gets soaked. Microbial growth.
Decay fungi, moderate decay of roof sheathing. Sheathing has probably lost 35% strength, maybe more.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 11/28/07, 10:58 PM
Moisture maybe but the bath fan had been disconnected ans covered. The nails sticking into the roof sheeting were not rusted, signs of moisture. Didn't take a moisture reading. Thanks to all for the good comments.
Old 11/29/07, 8:32 AM
msylvester's Avatar
msylvester msylvester is offline
Send a message via AIM to msylvester
Looks like mold to me, probably a pen-asp or cladosporium.
Mark Sylvester
P.I. Home Inspection Services
www.pihomeinspection.com
mark@pihomeinspection.com
Old 11/29/07, 4:32 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Robert
Only one way to tell for sure, do a mold test. In this situation I would use a swab and send it to Pro-Lab. Results in 24Hrs.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 11/29/07, 5:19 PM
Banned
It's mold. Good venting does not ensure a dry attic!!!
See: http://www.cmhc-schl.gc.ca/en/co/mah...gemare_001.cfm
From the above:
What To Do About a Wet Attic
The usual response is to increase attic ventilation. This is the wrong approach. In some cases, adding ventilation will actually pull more moist house air up into the attic and make the problem worse. The best way to fix a wet attic is to stop air movement, or leaks, from the house. Once this is done, the existing ventilation is usually more than enough to keep the attic dry.
And from a 1980's article, Attic Ventilation and Airsealing, from the NY State Energy Research and Development Authority:
"In fact, there is no guarantee that providing a specified area of passive ventilation openings will yield some desired level of of ventilation"
Old 12/15/07, 8:52 PM
dpotts dpotts is offline
I agree Brian. Ventilate all you want but without preventing heat loss and air movement ..... But for the original question; that is mold or other fungi untill proven otherwise.
Recommend "further evaluation by qualified specialist".
Old 12/17/07, 7:10 PM
gporter's Avatar
gporter gporter is offline
Advise for mold testing to cover yourself.
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 12/17/07, 7:16 PM
David P. Valley's Avatar
Do you think you can make that pic any smaller?
Looks like moisture accumulation which caused the mold looking build-up.
Old 12/17/07, 7:23 PM
Gable and ridge vent do not make good ventilation...air comes in the gable and out the ridge...nothing circulates down near the eave walls.
Still, it looks like evidence of condensation to me too.
Larry Kage, CMI
231 929 3525
Old 12/17/07, 7:54 PM
Dennis R. Goudreau Dennis R. Goudreau is offline
ditto
Interesting article about mold by litigation. gromicko IAC2 Indoor Air Forum 16 5/5/11 7:48 PM
Mold mcyr IAC2 Indoor Air Forum 5 9/13/10 10:31 AM
2 questions staylor5 Electrical Inspections 14 12/18/09 2:32 AM
Mold Remediation & Duck Cleaning Work-If Done Right dplummer Ancillary Inspection Services & Additional Topics 8 10/12/07 2:03 PM
Everyday Events Can Cause Mold jmckenna1 Miscellaneous Discussion for Inspectors 1 3/3/07 2:11 PM
