Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey Guys,
I have a low slope truss roof and unfortunately need to install baffles at rafter ends as the insulation is blocking air flow. The problem is I can't reach the ends. I have no idea how to proceed with this must do project. I thought about hiring it out but how will they reach it if I can't? Thanks |
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Can you possibly reach from the soffit area?
Hi Ian,
Do you mean remove the vents from outside and install them? |
Yes, I have seen that done a few times around here on the lower slope roofs.
That's good news, thanks. Is this usually done by a roofer or insulation contractor? I just had the roof replaced a few days ago and the roofing contractor told me that I had to physically find a way to do this from inside the attic. We are going to have a nice talk in the morning.
Well, you would have to remove one of the vents and see what you will be dealing with as far as obstacles. Alot of times these can be installed from the soffit side. but every situation is uniques, and there may be something hindering that from this approach, definitely worth a look though I would think.
Is it blown-in or batt? For blown-in, I just use a rake to reach down into the eaves and pull some back. For batt.... just pull on it.
Did you ever get your vents installed for your bath exhaust ducts yet? Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Hi Jeff, yes I did thanks. Broan has a model for like $40 that will pull a piece of tissue right from your hand.
Yea the midgets might be a good idea.
Alabama Home Inspections www.thebirminghamhomeinspector.com Home Inspections in Birmingham, Montgomery, Huntsville, and Tuscaloosa. |
I might remove the vent covers from the outside and cut-clear away.
What type of home do you own? and how old? |
I've always wondered why people elect to go with the quietest fans....
Best bet is if you have someone to 'reload' the baffles so all you have to do is work the center and pivot back and forth from the center area to the person reloading the baffles. Lessens the chance of a follow up project on teh ceiling below... If the baffle doesn't want to release from the pole after you finesse it into the eave area, give the pole a twist and break a little piece away to release it, assuming you are using foam baffles. My assumption is that you are talking 24 oc with the truss construction? You might be able to get away with every 2nd one. Easier with 16 oc, but still doable. |
You might also try using compressed air from the soffit side.
| Way More Intake To Supplement Minimal Exhaust Ventilation? | Ed Fako | Exterior Inspections | 1 | 12/19/08 6:07 PM |
| Cutler-Hammer CH breaker issue | Marc D. Shunk | Electrical Inspections | 4 | 5/27/07 2:04 PM |
| Robust views on issue of home inspectors | wblakey | Canadian Inspectors | 0 | 11/24/06 5:49 PM |
