Old 3/3/08, 5:38 PM
Erol Kartal Erol Kartal is offline
Please Note: Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Soffit Baffles
Today was the first time I've seen a builder use cardboard for soffit baffles.
Old 3/3/08, 5:44 PM
ldapkus ldapkus is offline
Default Re: Soffit Baffles
I had an inspection today where there was cardboard around the attic hatch opening to keep the cellulose spray insulation from falling into the home (or on your head) when you open the hatch. That was nice. No surprise or mess to clean up.
Old 3/3/08, 5:48 PM
Too funny.
I've heard about the use of this type of baffle, just never have seen them. I'm use to inspecting 103 year old dumps that don't even have soffit vents.
Old 3/3/08, 6:54 PM
Joe Funderburk, CMI's Avatar
Very common here. What's the problem with it? Why is sytrofoam better?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/3/08, 6:58 PM
Never said there was a problem with cardboard baffles. I did say I'm not use to seeing them.
Old 3/3/08, 7:01 PM
James F. McKee's Avatar
looks like a pretty neat install compared with what I am used to seeing...thanks for the pic....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 3/3/08, 7:10 PM
Adam Veitenheimer Adam Veitenheimer is offline
Please Note: Adam Veitenheimer is a non-member guest and is in no way affiliated with InterNACHI or its members.
That's crazy I didnt even know that was an option (of course I am new), is that effective??
Old 3/3/08, 7:38 PM
It can be but at some point the cardboard should be notched around the trusses so the dam it is creating extends to the outside of the top wall plate to preserve the insulation value of the wall system and reduce heat loss.
Larry Kage, CMI
231 929 3525
Old 3/4/08, 7:25 AM
Carla Horne's Avatar
Carla Horne Carla Horne is offline
Hi guys,
the cardboard baffles are used alot in modular construction.
I see it all the time here.
CJ
Old 3/4/08, 7:49 AM
David A. Andersen's Avatar
It can cause cold spots at the wall/ceiling if the insl. blower doesnt get it under the cardboard the six inches out to the eave. But is a neat job and does not collapse in the heat.
Old 3/4/08, 11:25 AM
Banned
The term used for these would be "ventilation chutes"
It appears that this builder just used regular cardboard sheets stapled to the bottom of the upper chord. There are better pre-made products.
http://www.jrproductsinc.com/vent_chutes.html
http://www.idimn.com/pages/ventilation_products.html
Installing ventilation chutes is only the first step. You must create an airtight wind deflecting "baffle" between the top of the exterior wall and the shute to keep cold air from infiltrating into/through/under the fiberous insulation installed on the wall top plate. This is not done well on most new housing!!!!
http://imageevent.com/iim.jsp?p=98&f...okoboji_images
Old 3/4/08, 1:58 PM
Troy Farmer's Avatar
Troy Farmer Troy Farmer is offline
Here in the west allot especially the attic hatches to prevent me from looking like a snowman!
Troy Farmer
Presidential Inspections LLC
Chapter President Southern Idaho
PO Box 2144
Eagle, Idaho 83616
208-573-5300
http://www.presidentialinspection.com
http://info@presidentialinspection.com
"He who can, does. He who can’t, teaches"
"Where would we be without Teachers"
Old 3/7/08, 6:01 PM
William J. Decker's Avatar
I see them all the time in new construction. For some reason, mostly in the 1 Mil + houses.
Guess they gotta save money somewhere.
They are OK to use, but most of the time they are not installed properly.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 3/10/08, 3:02 PM
Patrick Krzemien Patrick Krzemien is offline
See these all the time around here. I'll note in my report whether they are present or not. Cardboard is the most common material. The attic hatch is usually something more substantial than cardboard though.
Old 3/10/08, 8:08 PM
Peter C. Russell's Avatar
Do they deteriorate at all with moisture, not used here so much.
Eaves, Soffit, Fascia Mike Jewett Exterior Inspections 1 9/6/07 3:14 PM
Siding and soffit staining pominspections Exterior Inspections 8 2/21/07 5:22 PM
Gap in Soffit carolinainspector Exterior Inspections 6 6/23/06 8:56 AM
Soffit vents too small. Jay Moge Structural Inspections 2 4/2/06 12:28 AM
