Until you look at it through your thermal imager. . .
Jeff,
Pretty wild and impressive. Did you suspect something or just picked this up randomly? I went along with someone doing some motel rooms with an IR camera and like yours the walls (around the windows) looked normal but many had very obvious water intrusion going on. I did some of the checking with moisture meters and they were pegging out and in some rooms the musky odor was apparent but no visible signs of water. |
Part of my standard protocol is to "scan" the entire house at the beginning and end of an inspection. Generally, just for my own curiosity. I haven't had my "formal" training yet, so I don't promote thermal imaging as being part of the inspection.
This was at the end of the inspection so it was (for the most part) random. This is the kitchen ceiling after running the master shower for a few minutes. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 7/22/07 at 11:08 AM.. |
Nice catch Jeff.....those Cams are simply amazing!
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Jeff,
Which Flir camera did you purchase? I'm considering.... |
Dave,
I believe Jeff initially purchased a BCam, and quickly replaced it with a BCam SD... or I seem to remember that .... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Mike is correct. I have the BCAM SD.
Jeff;
Could you explain to me what the colors mean? Curious how all this thing works. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Well I'm paying $1600 to learn this, but I'll give you the simplified version
The colors are simply temperature differences, you'll notice there is only a 9 degree difference between the lightest and darkest areas of the image. The water from the leaking shower pan has changed the temperature of the drywall. The darker areas show where more water has accumulated or saturated. The darkest area is actually the drywall seam, you can see a slight paint "bubble" in this area in the "camera" images. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks Jeff.
I guess noone said education was cheap, right? ha. ha. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Jeff, Are you taking the Building Science course or Level oneThermography? |
Jeff,
Flir does have the more expensive B2 camera with the wide angle lens option. That's the exact camera I was thinking of purchasing. It allows you to view the entire house in one screen shot. Question - With your BCAM SD...Standing in front of a house, are you able to see the entire house (in the view finder) or do you have to slowly scan the entire exterior? |
jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Which is the camera that they use for all of thier sales pitches and brochures ?
Mic |
JP,
Those are great images!!!!! Bring them, and all pics you have taken to class. When you can get stuff like that with a BCAM your on top of it. Don't get too wrapped up in the high end stuff, we are still just HI's and until you go beyond that there is really no need for more. It is more important to get started than it is to wait to get the camera of your choice. A Yugo will get you to work so you can buy that Corvette! Anyone interested or planning to attend the ITC course and want more info. feel free to contact me. We (other NACHI members and myself) had a great experience in Boston last week. My head is still swimming from all the input from the course and those that attended. I don't think I sat in a class with so much accumulative knowledge in quite a while. Your not just preached to, the class members bring as much to the table as the course provides. If you go, take advantage of it and talk with your neighbors in class! They come from around the world and see things in a different light. If you can go to Boston, go. Folks from FLIR came by the class and rendered a huge amount of support to the class concerning their equipment and software. |
Also, anyone considering this should download Will Deckers PP on thermal imagining, take it to staples and have them print it out for you, then put it in a binder and study it before you go, it will help you tremendously understanding the course. Also Dave, get in touch with me and I will forward the contact info. of someone at Flir that will personally give you a tour and answer any questions you have. My brother Alan and I did and it was great, they are located in NO. Billerica of Trebble Cove Road. PS it was great to take this class with fellow NACHI members Dave from TN. and John from FL. |
| Inspector Wendy's Home Inspections-Service Areas | wforsyth | Miscellaneous Discussion for Inspectors | 57 | 9/5/06 11:10 PM |
