During a recent inspection where the builder used laminate flooring on the stairs, I found a condition that needs an answer. The question is about the 3" bullnose used on the leading edge of the tread, it was about 1/6 - 1/8 of an inch higher than the body of the tread. To me it appeared to be a trip hazard, if your heal got caught on it going down. I looked in the Florida code and IRC and could not find anything about the tread. Does anyone have more information on this issue.
Look on page 3. There is a 2% height variation that is allowed. Not sure how you would actually measure it, but it may help with your arguement.
David, the file was too big to upload - I sent you an email. Bill Last edited by wsiegel; 12/12/06 at 11:35 PM.. |
Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
The slope issue may cover this but it is the tread surface that is in question. please look at link to see photo.http://hisafetyfirst.com/html/cert2_11.html
http://hisafetyfirst.com/html/cert2_12.html http://hisafetyfirst.com/html/cert2_13.html maybe this will help you guys understand my situation. |
Here is a recent discussion on the same issue.
http://www.nachi.org/forum/showthrea...ghlight=stairs |
Did you measure the rails to see if any of the openings are wider than 4 inches??
Notify your client through report documentation of the obvious and let others figure out the remedy. No code reference necessary.
Here is the '06 IRC stair code: http://www.stairways.org/pdf/2006%20...C%20SCREEN.pdf "My opinion and experience has been that laminate flooring stairs are hazardous for a number of reasons. The list below is not all inclusive.
STAIRWAYS AND STEPS
ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 12/13/06 at 1:52 PM.. |
jinvernizzi is a non-member guest and is in no way affiliated with InterNACHI or its members.
The surface of the bull nose and tread (T&G) should be at the same level. Maybe the installer used one brand (ex: Armstrong®) bull nose and another brand (ex: TrafficMaster®)laminate for the tread. This might explain the thickness variation.
Another thought: the installer did something to raise the bull nose, either inadvertently, (e.g., too much adhesive), or on purpose, perhaps thinking this would prevent slipping. This is a case where the cure is worse than the disease. The installer could remove the material used to build up the bull nose, thus making the tread surface level. [Lots of luck removing the construction adhesive!] Finally, the installer may have used over-the-top step edge on the individual treads. This is to be used for a step down or landing, not individual treads. It appears to be a safety issue, even if the codes don't specifically address this. |
Thank Guys
I've only been Home Inspecting for just over a year. You guy's scare the hell out of me with all the talk of law suits and I don't need more problems. Thanks David |
Be afraid, be very afraid.
Happy Inspecting Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
David
Write it up in your report. The Builder would be crazy not to address this situation on his own, much less when you write it up in your report. Builders get lazy thinking some time, especially close to "Closing a sale". |
I remember being a newbie and very nervous. I simply noted every defect that I observed and kept my clients well informed of their prospective home. I've yet to see an unhappy client. |
| code for minimum floor space at top of stairs? | areid | Miscellaneous Discussion for Inspectors | 12 | 4/16/07 10:39 AM |
| Stair building Rules??? | sfalvey | Interior Inspections | 8 | 4/14/07 5:58 PM |
| Today's stair "issue" | jpope | Interior Inspections | 39 | 9/14/06 1:18 PM |
| 2006 IRC Stair Code | badair | Interior Inspections | 8 | 8/13/06 1:37 PM |
| How long can stair stringers be? | jfunderburk | Exterior Inspections | 13 | 4/14/06 8:40 AM |
