Old 2/3/09, 10:50 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default Stairs
Should these stairs have any kind of support underneath on the open side? Stairs went quite a ways up more than the pic shows and they were a tad bit wobbly. What are typical requirements? Thanks in advance.
Old 2/3/09, 10:54 PM
Wayne B. Wilson's Avatar
Default Re: Stairs
Well hand rail is wrong and no safety rail for starters , Just asking could a 4 inch sphere go between the steps, I would say a support post would help also
Old 2/3/09, 11:00 PM
Default Re: Stairs
Yeah, handrail was also < 11/2" from the wall, space greater than 4" on the riser space, and the top riser to the upstairs was a good 12" - I nearly fell when going to the basement! (Luckily, I had a change of underwear in the truck). Anyway, I can't seem to find anything as to understair supporting... any more help would be great. Thanks for the reply Wayne, hope all is well down your way.
Old 2/4/09, 7:07 AM
Rick K. Kie's Avatar
Rick K. Kie Rick K. Kie is offline
Default Re: Stairs
If im not mistaken its every 6' there needs to be support.
Rick Kie
Old 2/4/09, 8:38 AM
Unmoderated Guest
Default Re: Stairs
We can't see what supports that stringer on top (probably a beam or header), but normally full-depth stringers like the ones shown are designed to span the entire distance from top support to bottom. The stair probably pre-dates curent code requirements for railings and passage of a 4-inch sphere, but they might be pointed out as safety improvements, especially if there are infants or small children in the house, or elderly folks.
Old 2/4/09, 10:23 AM
nwagner's Avatar
nwagner nwagner is offline
Default Re: Stairs
Wobbly as in loosely fastened treads, the stringers lacking secure fastening to the basement floor, flimsy tread and/or stringer material? I commonly find staircases to unfinished basements have any combination of the three problems. Some handyman (I hope they weren't contractors ) have built these things with lumber that has no business supporting a coffee table, let alone a staircase ...
Old 2/10/09, 11:40 PM
Default Re: Stairs
1. Lack of a barrier on the open side.
2. Inadequate handrail length
3. Inadequate structural support of the stringer.
4. Exceeds modern safety standards
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 2/11/09, 12:53 AM
Unmoderated Guest
Default Re: Stairs
Exceeds modern safety standards??
You must mean "falls short of modern safety standards"!
Old 2/11/09, 11:55 AM
Default Re: Stairs
I guess that's kind of a crucial difference, Richard . Yep, that's what I meant.
(303) 717-8940
Comment for loft stairs rbrady Structural Inspections 19 7/20/08 4:29 AM
stairs and railings cwillick1 Exterior Inspections 8 6/12/07 10:56 AM
Stairs required? jmichalski Interior Inspections 18 3/5/06 5:47 PM
