rjennings is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just did an inspection and my client had a question I am not sure about. Once again, I know we do not enforce code but thought this was important enough issue to research.
Scenario = New construction and there is no step down to garage from the living room which is right next to it. Should there always be a step down in new construction? (Walking into this garage is like walking into an adjacent bedroom).Thanks |
In Phoenix there is generally a 4" step/grade change in the garage floor usually 4-5' from the door into a home...for a slab-on-grade.
New Construction should absolutely have the step-up from the garage to the living area. The height of this step-up varies from State to State.
Step needed to help stop any gas vapors or water from entering the house.
Code reference anyone? Come on Dale I know you have a code book.
I have seen many new homes without a step. |
Brian,
I think you are right, it might not be a code requirement here. But I don't ever remember seeing any garage slabs level with the interior either, mine isn't, how about yours? |
Common sense prevails on this issue. |
With that said, it would be derogatory to mention they might want to consider jackhammering their floor out and have it installed a few inches lower than the interior, huh...... I have never seen one installed level with the interior as Brian mentioned though.... |
David,
By the way...where in the heck do you get all the illustrations from? Man you have a lot of them.... |
Even though that is predominately beyond what you get paid to do.... |
I simply mention "No fume barrier at entry door from garage" in my report, and explain the situation to my client and leave it at that. With the cold winters here in Massachusetts, there are a few idiots out there that warm up their car in the garage. Attachment 3356 Last edited by dvalley; 10/7/07 at 5:41 PM.. |
| Garage step | kmilton | General Inspection Discussion | 5 | 7/27/07 6:02 PM |
| Evaporative cooler in garage | chellickson | Inspecting HVAC Systems | 9 | 7/23/07 1:08 AM |
| Garage ceiling & door header | Al Barb | Interior Inspections | 7 | 3/27/07 1:07 PM |
| Garage Door Safety...No Reverse...Advice Please | gliebig | Exterior Inspections | 33 | 3/17/07 8:28 PM |
| Step up from garage to house | dmacy | Exterior Inspections | 6 | 10/30/06 7:26 PM |
