Had this super chimney running through a childs bedroom
curious as to how you would have wrote it up. At the moment there is no woodstove in the living room directly below this bedroom and the current owners bought the home with this. I recommended WETT inspection on through floor connections and have qualifed professional install wall to protect from possibility of burn injury if chimney is used in future. ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 813 2353 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
If it's not connected to anything, it's not a chimney.
"Sounds good. We have plenty of those pine 2 x 4's to burn up." InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
it is a stainless insulated chimney, the through put connections are insulated as well. with out it working I still think there is a possibility of getting a burn from rubbing against it.
and yes thats why i mentioned it just because no stove is hooked to it , it is still a chimney ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 813 2353 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
This is triple wall insulated chimney pipe. At full temperature, yo can put you hand on it for a second..maybe 2. It is basically a zero clearance pipe. (although the rating might actually be 1 inch)
I do not think that this is a good idea, running it through a bedroom closet without an enclosure, 20 minutes and a sheet of osb would fix that. |
Billy ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 813 2353 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
Hey Billy, I was looking for the information on the sign guy who did your van and came across this old post. You are right to be concerned and advise on a WETT inspection. This installation doesn't meet WETT requirements.
As mentioned by another member on another thread awhile back (Chuck Crooker I think), these directives are for the benefit and safety of the occupants and there is no room for variance on the clearance issues. Have it inspected and certified by a WETT certified inspector. ( a little plug b for me Hope this helps! Steven R. Butts, CD, CHI, CWI, CWS Home Select Inspections Inc. Kingston On 613.483.4308 www.HomeSelectInspections.com www.Inspectorpages.com/sbutts |
[quote=mroberson]This is triple wall insulated chimney pipe. At full temperature, yo can put you hand on it for a second..maybe 2. It is basically a zero clearance pipe. (although the rating might actually be 1 inch)
Mike, I don't know how you can claim this is a triple wall insulated pipe by looking at a picture? The standard pipe used here is an insulated with a 2" clearance to combustibles. Zero Clearance is a brand name, not an installation guideline. There is no such thing as zero clearance from combustibles (think pyrolysis). Steven R. Butts, CD, CHI, CWI, CWS Home Select Inspections Inc. Kingston On 613.483.4308 www.HomeSelectInspections.com www.Inspectorpages.com/sbutts |
WETT #572 Master System Advisor |
From South of the Border -
The Chimney is not connected to anything and is not being used at this time. In my opinion if this was to be connected to a fireplace or other fuel burning fixture (wood, gas, oil, whatever). it would be a safety hazard as installed. We recommend removing it, OR if it is to be used - having a licensed and competent ......... (whatever they call them in Canadia) evaluate the chimney installation and repair or modify it as needed ensure safe and proper operation. PS - We also suggest hiring a home inspector with a Thermal Imaging Camera and doing a Thermal Scan for hot spots or weak areas prior to use (the last comment is to help the IR guys pay for the cost of their new cameras). Last edited by dbowers; 8/31/08 at 11:16 PM.. |
William even if there was a woodstove attached to this chiment running full bore, the surface of this chimeny will reach about 120 deg F. and will not burn. You can advise the homeowner to frame it in it they wish allow a minimum of 6 " clearent from the wall stud suirrounding the chimeny.
** The minimum clearance to combustibles required for most insulated metal chimneys in Canada is 2 inches. |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 8:16 PM |
| Panelboard in childs bedroom | charper | Electrical Inspections | 11 | 7/8/07 2:01 PM |
