Old 10/3/09, 1:43 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Question Is tempered glass required here?
There was another window in the enclosure that was tempered. This one is right at the edge. Should it be tempered also?
Find an InterNACHI certified Delaware Home Inspector (and anywhere else in North America)
Old 10/3/09, 2:30 PM
arook arook is offline
Please Note: arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Exclamation Re: Is tempered glass required here?
Yes per NJ's version of IRC2006 for new construction since part of the window is over the bathtub.
Glazing in any part of a building wall enclosing a bathtub. R308.4
We are not code inspectors, so I always point it out as a safety upgrade NOT as a code defect.
Old 10/3/09, 4:31 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Is tempered glass required here?
If it's required for this age of home and it's not there why not just call it a defect and not a safety upgrade?
www.MauiHomeInspections.com
Old 10/3/09, 4:45 PM
Chuck Evans's Avatar
AFIK all of that translucent, pebbled glass qualifies as safety glass. Afterall, it's made for use in such areas.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 10/3/09, 9:04 PM
rbrady's Avatar
The glass actually starts at the edge of the tub, so you could argue it's out of the enclosure. The code seems somewhat vague on this issue, especially if you consider where the "standing surface" would be.
Old 10/3/09, 9:09 PM
Well, I'd err on the side of caution if I was unsure which I'm not, in that situation.
Larry Kage, CMI
231 929 3525
Old 10/3/09, 9:10 PM
I call it out as a safety upgrade, because I leave it up to the building inspectors to quote code.
If I called it a defect, the first question that arises is, "Why is it a defect?" It's much easier to answer it from a home inspectors point of view by saying, "Because if you slip and put your elbow through the glass, it will shatter instead of having jagged edges - hopefully reducing your injuries." rather than saying, "because it doesn't meet code."
Old 10/3/09, 9:17 PM
I agree.
Old 10/4/09, 10:22 AM
Mark S. Tyson Mark S. Tyson is offline
do not assume that because the glazed opening is obscure that it is safety glazing, that is not always the case. all safety glazing must carry a permenantly etced identification label that would require the destruction of the glazing to remove the label. with the opening being partially over the tub and if it is not safety glazing i would note it as a safety concern
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Old 10/10/09, 8:44 PM
Allen L. Catterton's Avatar
Allen L. Catterton Allen L. Catterton is offline
I noted this window last month as a safety concern. The deck was added and you can see the reflection of the steps off to the right leading out of the swimming pool. I can visualize a rambunctious kid running down those steps and tripping through the plate glass window. Not good………
Old 10/10/09, 10:23 PM
Brian C. Hoagland Brian C. Hoagland is offline
Well OK. on all manufactured products made for resale. This is a great example of why we are NOT code inspectors. I have a custom shower enclosure in my home that I had manufactured and sent out for the temperuring process. It is etched glass by an artist. It has no permanent marking. I Have the receipts. The glass had to be formed into the custom shapes prior to being tempered. While I agree that it is best to point out that the glass may not provide an adequate measure of safety performance based upon observation I would recommend that the customer pursue due diligence to determine if the application meets their own measure of safety performance.
Old 10/10/09, 11:25 PM
James H. Bushart's Avatar
Please not that the IRC and IBC no longer consider "tempered glass" as safety glass.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 10/11/09, 1:06 PM
i have ordered the 2008 updates but have not recieved them as of yet. is that the version that disallows tempered glass? i know that the 2008 version has made fire sprinklers a requirement in new construction single family homes. wonder what that costs?
Mark S. Tyson
Member N.A.C.H.I.
IAC2 certified
Old 10/11/09, 4:44 PM
You are referring to the 2009 version.
I am not sure when the requirement changed, but there is a required inscription on the corner of the pane for the glass to be considered "safety glass" and tempered glass does not get that inscription.
As for the sprinkler systems...homes that are being built with them are being sold quicker than those without them according to my local fire marshal. Get ready for this to spread.
James H. Bushart
314-803-2167
Old 10/11/09, 6:42 PM
Jim, you lost me on that one.
Both Safety and tempered glass are marked and identified in there on way as such they are.
Every piece of tempered glass must have a permanent stamp or logo to signify it is tempered glass. However, there are no standards which regulate which surface of the glass is to receive the stamp or where the stamp is to be placed on the surface. Tempering stamps can face in or out on an insulated glass unit.
Attic access ladders and tempered glass moliver General Inspection Discussion 4 10/13/08 1:49 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
Emergency Lighting (commercial) mcyr Electrical Inspections 24 6/10/06 11:06 AM
