dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
So I'm walking on an 8 year old tile bathroom floor, and it feels like I'm crushing the mortar underneath as I walk. There is deteriorated grout between the tiles on several areas. As never having laid tile before, what went wrong during the install? I can attach pix if you want, but I'm at the job now and haven't uploaded them yet. Thanks
It appears that you're walking on unlevel tiles. Probably improper backing.....Simply have it evaluated and estimated for repairs.
Thanks David. I'm reaching on this one.....very clean.
Thanks Rob. Regardless, for a water resistant membrane, I do not see it lasting much longer
From what you describe, they need to re-tile.(after they fix the problem underneath.
Bad tile job, too much deflection in subfloor, wrong or not enough adhesive, lots of variables
http://www.tilemagonline.com/goldbook 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Tile appears to be installed inconsistent with any manufacturers specifications I have even read - ie - (Amateur Installation). Have a tile contractor repair is necessary
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
How the heck are you? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Dylan
I don't think it totally necessary that you pinpoint the exact cause...which is most likely improper initial installation, I would just report loose ceramic tile on bathroom floor.... |
If I can jump in here... Is the crunching coming from under the tile? Or is it from the grout that has dried out and come out from between the tiles?
If it is the grout, then it was probably caused by to dry a mixture, or allowing the grout to dry out too much during installation. (I've had to patch a few areas of my own bath because I let the grout get to dry.) If it is from underneath, or if the tiles are moving, then what everyone else has already said. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
I agree, I am not looking to diagnose the problem for my clients sake, just mine. I'm telling the client to re-tile. I just like to know the why's and how's whenever I can. And on this board, there are plenty of them to be found.
Hmmmm. Well, you don't put grout under the tile, only between them. Mastic goes under, so that might be part of the problem.
Dylan having installed thousands and thousands of tile i can tell You there are a number of reasons you get what you saw today....number one reason...movement ...could be improper sub floor installation..improper sub floor material..improper adhesive...wall tile installed as floor tile the list goes on...the major problem with ceramic floors in my opinion is improper preparation and amateur installation..if you have any more specific question i'd be happy to try to help....jim
| Moisture Readings For Tile Enclosures | jevans | Interior Inspections | 10 | 7/17/08 8:14 AM |
| Bathroom grout / where tub meets wall tile. | dnasser | Interior Inspections | 6 | 5/22/08 1:05 PM |
| Removing an existing ceramic tile | dduffy | Interior Inspections | 16 | 10/19/07 7:44 PM |
| Cracked flue tile | bknowlton | Inspecting HVAC Systems | 6 | 2/1/07 11:37 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 4:52 AM |
