New construction inspection today in Los Angeles. . .
What am I missing?
These would be great for toddlers |
Ah-ha.
I was focused on that nice flat area at the right where I could put some potted plants. Glad that's not the issue here. That was close.
Shag carpeting on stairs is a trip hazard. Its also not fashionable.
Is shag carpeting back in fashion? Personally, I prefer my shag carpeting in avocado green.
4 possible issues but i'm not up on cali. code
tread nosing too thick look at the measuring tape 8 1/2" rise wall require guard railing hand rail is incomplete ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 9/12/06 at 10:11 AM.. |
The measurements were a bit rough (tape pressure on the thick carpet) but we're allowed 8" in CA. Wall gaurd or rail was incomplete, which is what the tape was referencing. Handrail was incomplete based on my interpretation, but not that of the builder. We'll see where this falls in the next few days. Quote:
The first four steps above the landing were lacking their required protection. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 9/12/06 at 12:31 PM.. |
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think you're correct Jeff on each of those issues. Hand rail is required if more than (1) riser. Guard railing is required at both sides of the stair well with hand railing elevation of 34-38".
I normally list those items as an "unsafe condition" and try to explain to the parties involved what hazards are at issue. The builder however always says "It was signed off by the AHJ". As you and I both know, California is filled with construction defect litigation issues all of which were signed off at some point in time "By the AHJ" Good Luck! |
I don't believe I have ever found two handrails in a residential stairway in any of the states that I have worked in. In Jeff's picture, the handrail is going to go on the opposite wall so that I can put some nice potted plants on the other side. NACHI 2005 U.S. Member of the Year
Two hand rails are required only when the width of the stairway exceeds a specific dimension, however, I believe there is an exception with regards to single family residential dwellings (I can check on that if anyone is interested). There is no exception for guard rails/walls. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I'm not seeing an issue with your pictures yet. Can you explain further? Thanks.
The issue is in the wall where you want to put your potted plants.
The top of the guard wall is only 13" above the walking surface of the tread (as shown in the photo) where it is required to be a minimum of 34". IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
These dimensions are required to be a minimum of 34"
+ or -13 1/4" + or - 21 1/2 " next step down is + or - 29"-30" all are constiantly below the required railing height left wall handrail is absentbythe way those are pot plants not potted plants on that rail put down the bottle and look closely grin ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| Need help with todays inspection | prussell | Inspecting HVAC Systems | 4 | 1/29/07 10:28 PM |
| todays findings | ecox1 | Exterior Inspections | 2 | 1/6/07 10:06 PM |
| 2006 IRC Stair Code | badair | Interior Inspections | 8 | 8/13/06 12:37 PM |
