Old 4/16/11, 11:51 AM
Charley L. Bottger's Avatar
Default Townhouse firewall
The townhouse attic on the right is above the one on the left and not directly connected would a fire wall still be required this one did not have one installed. In my opinion as long as the dry wall is fired rated where the two are directly connected would be all that should be required What say Yea
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/16/11, 2:55 PM
Vern Mitchinson's Avatar
Vern Mitchinson Vern Mitchinson is offline
Default Re: Townhouse firewall
The fire wall must be 100% sealed between the two dwellings. If the fire migrates into the attic it is very hard to stop and the fire will spread into the adjacent unit. The Alberta building code was revised because a few years ago 38 dwelling units burned because the fire spread into the attic from one unit to the one next door.
Vern Mitchinson_CCHI_CMI
Registar
AlbertaNACHI
International Association of Certified Home Inspectors of Canada
Old 4/16/11, 4:46 PM
David A. Andersen's Avatar
I assume you are talking about the wall "above" the other (lower) unit?
Only required where they connect (attic to attic). Or attic to adjacent wall of the other unit.
Exterior is already fire rated because of the siding used.
BPI# 5015804
Old 4/16/11, 5:05 PM
Barry Adair's Avatar
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 4/16/11, 10:42 PM
Yes where I placed the red arrow the two attics do not make contact with each other I did not take a pic of the back side I should have but did not. Here is a pic of the attic side no dry wall
townhouse-firewall-7-stoneridge-pc-4-15-11-104.jpg   townhouse-firewall-7-stoneridge-pc-4-15-11-002.jpg
NACHI Member
State License # 130
Old 4/16/11, 11:32 PM
Michael R. Boyett's Avatar
Assuming this property does meet the townhome definition then yes, that upper attic wall should be a 1 hr separation wall. The 2003 IRC says:
R317.2 Townhouses. Each townhouse shall be considered a separate building and shall be separated by fire-resistance-rated wall assemblies meeting the requirements of Section R302 for exterior walls.
Also see the diagram below which represents your situation.
Asbestos Cement-Based Siding as Firewall krigler Interior Inspections 17 4/20/10 1:06 PM
Garage Firewall? slemarr Interior Inspections 3 5/1/09 9:13 PM
Can crawl through condo attic firewall? (Pics) Brian T. Harris Interior Inspections 4 12/17/08 2:24 AM
Garage Firewall jfunderburk Structural Inspections 19 4/9/06 7:23 PM
