ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Client wants to install plasma TV on wall above (gas) fireplace mantel. Is this OK?
Thanks |
Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Does this fireplace have a fan unit installed? Is there a mantel above the fireplace? Is there is an alcove above the fireplace where they can recess the TV? I would be very wary of installing an expensive piece of electronics above a fireplace with a fan unit due to the heat it puts out over and above a normal gas unit. I think it would shorten the lifespan of the TV with the increased heat. IMHO.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
A dealer of flat-screen TV's told a client of mine that installation above a fireplace was not recommended by the manufacturer. Sorry, I don't know names or brands.
Erol,
You may want to pass this info on to the client. http://www.plasmatvbuyingguide.com/p...fireplace.html ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Thanks guys. Barry, you remind me of the 'Shell answer man' if you're old enough to remember him.
Just try to help when I can and the net makes my job easy Don Morrow was his name Here I am in another life
| Thermostat location | Raymond Marsh | Inspecting HVAC Systems | 10 | 11/11/07 11:42 AM |
| Thermostat location | kweiss | Inspecting HVAC Systems | 13 | 8/30/07 2:38 PM |
| Private plumbing main shutoff location | jburk2 | Plumbing Inspections | 9 | 8/19/06 4:23 PM |
| A/C location of expansion device vs line temps. | bking | Inspecting HVAC Systems | 9 | 5/29/06 4:16 PM |
| Switch location | rdawes | Electrical Inspections | 6 | 2/1/06 3:33 AM |
