Old 9/20/10, 10:31 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default under sink mold...Question
This is a small guest house kitchen. Separate from main house.
I observed some mold stains under the sink. It looks like it came from
a leak that has now been repaired. The undersink area is now dry
and does not smell of mold. Do I recommend a mold inspection?
My opinion is just to replace the stained drywalll.... The leak has been repaired.
Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/20/10, 10:43 AM
Default Re: under sink mold...Question
Mold spores are still there. Recommend removal and repair. There is evidence of mold like organisms on all three sides and base of the sink.
Usually, this is a sink base cabinet or sink base front between cabinets, why is there drywall on three sides?
Have the contractor wear the plastic gloves left there for convienence.
Old 9/20/10, 10:49 AM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Just make sure that they create a containment area so that they don't spread the spores throughout the house during removal.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 9/20/10, 12:13 PM
Thanks...
Old 9/20/10, 10:45 PM
James E. Braun, CMI's Avatar
The whole cabinet will need to be pulled. Mold neds to be remediated to IICRC S520 standards.
Old 9/21/10, 7:04 AM
Here is the link.
http://www.certifiedcleaners.org/pr_...ved-S520.shtml
Old 9/21/10, 11:10 AM
Brian E. Kelly's Avatar
Originally Posted by mcyr View Post
This is funny.... notice the Law was passed to protect the Public from the remediators and not mold..
“There has been a recent push for legislatures to develop laws and guidelines that protect consumers who use mold remediation services,”
Paint the cabinet and call it a day.
Old 9/21/10, 11:26 AM
Brian, you don't paint over mold;
You remove it;
If a wall in your home has been taken over by mold you can not simply paint over it because the mold will resurface through the new paint. Kevin Bristol, President of Advance Mold Remediation
and expert in mold control with the Environmental Protection Agency, says, "you want to make sure that you get all the mold spores" before you, "go back and put on the paint".
Old 9/21/10, 4:12 PM
If a wall in your home has been taken over by mold you can not simply paint over it because the mold will resurface through the new paint. Kevin Bristol, President of Advance Mold Remediation [/COLOR]
[COLOR=blue]and expert in mold control with the Environmental Protection Agency, says, "you want to make sure that you get all the mold spores" before you, "go back and put on the paint".
What a crock of crap....
Mold is ubiquitous.
Remember boys and girls,, "Mold is Gold"
Old 9/21/10, 4:37 PM
OK, you can paint over it if you want.
But the EPA recommends this:
Method 3: High-efficiency particulate air (HEPA) vacuum after the material has been thoroughly dried. Dispose of the contents of the HEPA vacuum in well-sealed plastic bags.
Method 4: Discard - remove water-damaged materials and seal in plastic bags while inside of containment, if present. Dispose of as normal waste. HEPA vacuum area after it is dried.
http://www.epa.gov/mold/table2.html
Old 9/21/10, 5:07 PM
SMALL - Total Surface Area Affected Less Than 10 square feet (ft2)
Wood surfaces 1, 2, 3
Select method most appropriate to situation.
All from the EPA website you mentioned...
This is method 2 of the cleaning protocols "Method 2: Damp-wipe surfaces with plain water or with water and detergent solution (except wood —use wood floor cleaner); scrub as needed."
Spray some lemon Pledge on it, dry it, and paint it.
If mold was as Deadly as some here would have you believe, it would be on every news channel in every city every day of the week.
But what is on TV News today is Bed Bugs, which for the most part are not even a Health Risk, mostly just annoying. (hmm a lot like me..hhahahah )
Old 9/21/10, 5:12 PM
Well since you like to pick and choose the words of anything to fit your fancy, I will choose mine from the same website.
Use professional judgment
Old 9/21/10, 5:24 PM
James F. McKee's Avatar
just don't lick it.....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 9/21/10, 5:26 PM
Jim, is that a word of wisdom from experience?
Old 9/21/10, 5:34 PM
Christopher Currins's Avatar
Brian *Bed Bug* Kelly......That has a ring to it.
Christopher Currins
Certified, Licensed
Mold Question rmarton Ancillary Inspection Services & Additional Topics 11 2/16/10 5:27 PM
Dr. Shane says every home should be tested for mold. gromicko Ancillary Inspection Services & Additional Topics 106 6/7/09 3:36 AM
Mold Remediation Co's Pass Hidden Test dplummer Ancillary Inspection Services & Additional Topics 6 2/18/08 9:10 AM
Mold won't grow in Arizona,& other falsehoods dplummer Ancillary Inspection Services & Additional Topics 4 1/22/08 5:41 AM
Mold Remediation & Duck Cleaning Work-If Done Right dplummer Ancillary Inspection Services & Additional Topics 8 10/12/07 2:03 PM
