Hey Guys-
Any of you seen a stringer constructed like this? It looks like they just sawed/chiseled out the supports for the treads but for the most part, the treads were only resting on about a 1/2" ledge. Seems like a lot more work than just cutting out the stringer like normal and only providing a 1/3 of the support. Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks unsafe.
There are a few issue there. |
Actually yes, it was common practice and acceptable at one time..... the treads and risers were often thicker as compared to the nominal size of lumber today.
If you ever look at prebuilt staircases you will see the similar thing. They glue, screw and stable things to death in order to maintain structural integrity. This one looks like they tried to imitate those designs........poorly I may say. Looks like some some sort of number 2 or 3 pine........... How is the home by the way and what is the width of the stairs.....looks like 36 inches. |
I didn't measure the stair width but I agree, probably 36". The home was a late 70s brick home. Looked very nice from the street but as I got into it found several shortcuts. Rigler Home Inspections Hays, KS 67601 785-656-0272 |
I once worked for a modular home company that did similar, but not the same, staircases. We had this awesome router table and when programed with the rise and run would route out the stringers, to about 3/4", and the tightness of the tread/riser fit along with the glue and screw made them very sturdy. I wish I had taken pictures of some of the cool machines we had then.
George Russell George Russell Professional Inspections Austin,Texas TREC # 10215 512-296-9538 http://georgerussellprofessionalinspections.com/ http://www.facebook.com/austinhomeinspections |
when done correctly they are very strong however when done by DIY's they usually fall apart.
http://www.espstairs.net/boxstair.htm |
Norm has done this type of stringer on one of his shows, not as ugly looking as that though
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Yup there is that bad boy router table....what a cool piece of equipment!!
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| Selected Electrical Incidents and Occurrences - First Quarter | pabernathy | Electrical Inspections | 0 | 12/2/07 1:43 PM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
