Old 1/25/06, 10:44 PM
pcarter-old-04's Avatar
pcarter-old-04 pcarter-old-04 is offline
Please Note: pcarter-old-04 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Question Vent in Chimney
Seems to be a lot of unsual inspections occuring around the country today. I find this during a inspection today. I don't see the purpose for it and its tied into the flue. Anyone seen something like this before. The fireplace is used as a heat source for the home and has ductwork to the furnace air handler and distributes heat through the furnace ductwork.
Old 1/26/06, 7:32 AM
Mark R. Long's Avatar
Mark R. Long Mark R. Long is offline
Default Re: Vent in Chimney
Do you have a picture, Patrick? Based on your description it sounds as if a creative homeowner is trying to use ductwork to evenly distribute heat throught the house in much the same way as a central furnace, and is using the air handler of the furnace to do this. I've come across this a number of times in my area where a lot of people use wood for heat. Just need to be sure that the combustion area and/or the chimney hasn't been compromised.
Mark
MD HI Lic # 30090
BPI Certified Building Analyst
PA DEP Radon Cert # 2457
Certified Home Energy Tune-uP Inspector
Old 1/26/06, 4:39 PM
David P. Valley's Avatar
Patrick,
Attachment 785
Old 3/8/07, 4:48 PM
Chimney Pro's Avatar
Chimney Pro Chimney Pro is offline
Please Note: Chimney Pro is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Patrick,
There are furnace-rated fireplaces and fireplace appliances that are designed to be the sole heat source for a home. And yes, they connect up to ductwork in the home to distribute the heat throughout the home. Have a great day! -Tom
Old 3/8/07, 5:48 PM
Joseph Hagarty,  CMI's Avatar
http://www.chasetoppers.com/
Interesting product (particularly the masonry application).
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 3/8/07, 6:38 PM
John Lomonaco John Lomonaco is offline
You need to explain your self in more detail!!!!!
Unsual inspections around the country is a broad statement.
If the fire place is tied to the furnace in any way you have a serious problem.
You cannot combine various combustible materials in a single flue.
John
</IMG>
Old 3/13/07, 1:56 PM
Thanks Joseph, we appreciate your comments! -Tom
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Air admittance valves everywhere apfaff Plumbing Inspections 13 4/16/07 9:17 AM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 5:22 PM
PVC vent at chimney dmacy Inspecting HVAC Systems 2 9/22/06 1:32 PM
Chimney vent dmacy Inspecting HVAC Systems 2 7/31/06 7:33 PM
