Old 1/5/10, 9:58 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Default Water under marble tile
Today I was called to a clients house that cost about $5,000,000, he has a marble tile floor that is a slab on grade residence and there is discolarion to the sheen of the marble in a certain area. Nothing showed up on the thermal infrared camera, but using the protimeter survey master you can plainly see the high mositure where the discoloration is taking place. What I would like to know is what is the best way to determine exactly where the leak is taking place without having to rip up all the tile. Is there a tool out there? Once again it is in the supply line, because with all the water off in the house you can see the water meter move ever so slightly, but its dead center of his house and he is not a fan of removing the tile. Thanks in advance.
Russ
Find an InterNACHI certified Kansas Home Inspector (and anywhere else in North America)
Old 1/5/10, 10:01 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Re: Water under marble tile
Any photos? Could it be surface water?
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 1/5/10, 10:14 PM
The pics don't really show the sheen or lack of it...very slight, but evident none the less. It was not surface water. I really do think there is a small hole in the PEX plumbing located within the slab of the residence.
Old 1/5/10, 10:37 PM
OUCH!!!! That will cost someone.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 1/6/10, 12:20 AM
Joe Funderburk, CMI's Avatar
This is all I could think of.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 1/6/10, 10:19 AM
Would an IR camera help??
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 1/6/10, 11:15 AM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Without knowing the layout of the house its difficult to say but I have had success just abandoning lines and rerouting them overhead.
www.MauiHomeInspections.com
Old 1/6/10, 4:29 PM
I have been successful in turning on the hot water side for about 15 - 20 (some times longer) minutes......mean while I am diagraming the home to determine the plumbing layout..... so far it has worked for me. (even when it is a supply line, the heat from the hot water side should effect those water around same)
I would also expect a home that size would have drawings...... I would locate them as well as trying to find out who the plumber / contractor was that installed same.
There are no instruments per se that will detect the origination.......I went through this last year on several slabs including at a large apartment complex..... the method I described above worked for me.
Let us know what you come up with...
Jeff
Old 1/6/10, 4:52 PM
Bob Elliott's Avatar
Question for you IR guys.
Why cant you see the water ?
I assume it is a different temp from the surface.
Also Russell, how do you know it is a leak from dis-coloration evidence when something could have been splilled and you are getting trace readings.?
If problem is that marble and water are the same temp,would not heating the marble surface help ?
Old 1/6/10, 7:29 PM
Wayne B. Wilson's Avatar
I wonder if ultra sonic could find a leak if the was one, I have some success with it in the past.
Old 1/6/10, 9:19 PM
Chuck Lambert Chuck Lambert is offline
Unmoderated Guest
Please Note: Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
It would probably be better to cool the marble with a fan and due to convection the moisture would show with the IR. If the marble is heated the moisture will also heat and not really be distinct from the surrounding marble.
Russ,
Ultrasound is one way to go. Those leak detectors work great! I had a cold water slab leak and could not find it with my IR called in an ultrasound and they found it in about 10 minutes (almost wanted to by one after that). Also removing one section of tile should not be that difficult. As was statde previously re-routing is also and option.
Just a few thoughts,
Chuck
Old 1/7/10, 2:58 AM
Tim Spargo's Avatar
Wayne,
That's what I thought as well. I've had plumbers perform ultrasonic leak detections and give an X marks the spot. I've done this with copper though......
Would be curious is pex irradiates sound like that of when a pin hole is present in copper.
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 1/7/10, 5:42 AM
Gerry Pallotta's Avatar
Gerry Pallotta Gerry Pallotta is offline
Send a message via Yahoo to gpallotta
I have been told,once marble discolors this way the stain will never go away even when dried. It may come to ripping out the marble anyway.
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/7/10, 6:51 AM
ldapkus ldapkus is offline
I had one a couple weeks ago and couldn't find it with IR. Ultra sound should find it if the water supply line is leaking enough to see the meter moving. Around $1000 for a decent unit.
Old 1/7/10, 12:48 PM
Peter Summaria Peter Summaria is offline
Just a few questions: How recent is this stain and how old is this floor? Does the stain come and go. Certain marbles if not installed with the correct floor mix or adhesives can cause staining over long periods. Could it be an area where ground water would be a problem?
Reverse Osmosis phinsperger Plumbing Inspections 3 10/30/07 6:28 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
