During an inspection I found this white powder covering the insulation in the attic. It was up to an inch thick in areas. Does anyone know what this is and why it would have been put in the attic?
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Perhaps a drying material any signs of moisture stains under it? or smoke damage.
Also i was wondering if it was some type handy mans pest control.
I did not see any signs of moisture or smoke damage. Pest control could be a possibility. I thought it might be something to cover up pest urine smells. I have been in mice infested attics with a very strong urine smell.
The first time I saw it, I thought it was sugar.It looks like that, but is much lighter.
Harold J. Lowe C.M.I., C.C.I. Eagle-Eye Healthy Home Inspections Sharondale Academy of Home Inspections www.healthyinspections.com harold@cannachi.org haroldjlowe@hotmail.com home-905-576-4337 cell-416-912-0852 CanNachi Director of Education Board Certified Master Inspector Certified Infrared Thermographer Pro-lab Certified Mould Specialist IAC2 Certified Indoor Air-quality Consultant Certified Commercial Inspector Toronto/Durham/Kawarthas Proud InterNachi Member # 06091197 |
measter is a non-member guest and is in no way affiliated with InterNACHI or its members.
My guess is this is a weapons grade anthrax storage facility.
Make sure your immunizations are up to date and you can start a new ancillary service- anthrax testing. |
It kind of resembles the insecticide, preservative, fire retardant boric acid but I've never seen that much used or spread like that.
Same here. We have some in my attic that was put there by the company we have contract with but it was a light dusting, nothing like that. That has got to be weighing down the insulation. I suspect overkill in application.,
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
My first two thoughts were (half jokingly)...
1) Baking soda... to get rid of odors from any number of things... 2) Lime... to aid in decomposition... Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
I would definitely encourage the buyer to have it analyzed before buying the home. The problem with chemical substances is that what was once considered safe may not be considered safe now, such as lead. I sure wouldn't mind knowing just out of curiosity. I sure as heck have never seen anything like it.
Matthew Klein, P.E., M.B.A. Criterium Engineers PO Box 181503 Cincinnati, OH 45018-1503 Phone: 513-474-9600 FAX: 888-747-0427 E-mail: Criterium-Cincinnati@fuse.net Website: www.Criterium-Cincinnati.com |
The link (2nd) that you provided shows a picture of it in fine granules that looks exactly like the picture. |
Possibility -- Boric Acid Powder
Read all about it. It's also commonly used as a fire retardent just like Mike said and I agree it looks excessive. http://www.alsnetbiz.com/homeimprove...oric_acid.html Question: Could it cause an health hazard to the occupants? Answer: It would certainly present a far greater risk than either radon or indoor mould. Having said that, it is not likely that the presence of the material (if it is boric acid) would result in a toxicologically significant exposure. Boric acid is a weak acid, and a simple field pH test would certainly confirm whether it had base or acid properties, but would not identify the material. However, if the pH was elevated, you could conclusively rule out boric acid. Cheers! Caoimhín P. Connell Forensic Industrial Hygienist www.forensic-applications.com Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes Last edited by bboerner; 3/14/10 at 7:18 AM.. |
| Uvented Attic | jmckenna1 | Thermal Imaging, Infrared Cameras & Energy Audits | 6 | 2/1/10 2:07 PM |
| Attic Insulation Deteriorated?? | Skip Erwin | Inspecting HVAC Systems | 3 | 10/4/07 8:31 AM |
| White Powder on Attic Trusses | jcooper2 | Ancillary Inspection Services & Additional Topics | 22 | 1/5/07 5:22 AM |
| White Powder Residue | kevin.raymond | Inspecting HVAC Systems | 1 | 9/26/06 6:04 PM |
