This attic has about 14" of fiberglass batt insulation in the floor. It also has about 6" under the roof.
I am curious why somebody would install the insulation in the roof and gable end and leave the paper vapor barrier exposed when the rest of the attic has adequate insulation. The roof has a ridge vent and soffit vent, the roof also has "proper" vent between the insulation and the roof deck to vent to the ridge. The insulation does block some of the ridge vent from allowing the attic space to vent. This part of the attic is a recent addition as a conversion from a garage. The rest of the house does not have the roof insulated but has a gable vent, soffit and ridge venting. Any thoughts? and comments on the roof being insulated? I do know sometimes sprayfoam insulation is used on the roof, but when it is used it usually is not vented. When viewing the picture, the black on the paper is ink not mold. Thanks, Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
As long as there is proper venting from the soffit to the ridge vent, the roof ventilation is satisfied. The rest just seems to be a lot of over-kill.
But, then...what would I know?? I'm just an old fart trying to get by... "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Check out that insulation and read the backing on it. If that is regualr batt roll insulation it is installed wrong. The label on the back side says that the paper must be laid flat against the surface. If not, it will aid in the rapid spread of fire.
is this house near an airport?
I don't think they make 7" roll insulation. They make 5 1/2-inch and 9-inch, which when combined would give approximately 14 inches. The 9-inch may actually be 8 and a fraction.
wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
The top one is installed properly as well. It's face down. The paper is facing the conditioned space. If you turned it the other way, it would have the wrong side towards the conditioned space and would collect moisture in it which is incorrect.
So, other than the paper being exposed because of the fire hazard this should be fine, right?
I see the paper exposed on many, many jobs. Builders and DIY's can't read the manufacturers installation instructions on the product that's in their face when they install it. Oh well, I guess it's job security. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
There is no reason to install insulation to the roof decking, unless it is for sound deadening (sp) as suggested before. BUT, why not just install more insulation to the ceiling????? Make sure there are baffles installed for proper air flow to the roof decking.
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
From the backing on the insulation.
I would be concerned about ventilation also. It appears as though the soffit vents are blocked. This will cause excessive moisture in the attic space. Check for mold on the seathing underneath the insulation.
a wise man once told me, "life is short, so learn from your mistakes, but more importantly learn from others mistakes as well because you don't have time to make them all yourself" Regards, Mark |
I still think it's just a case of "over-kill". "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
It's not a case of 'overkill'.
It is a case of wrongly installed insulation in the rafters. The only insulation that is having any effect on conserving energy in this structure is the attic floor insulation....unless the attic is conditioned (ie. heated/cooled). Paper facing of insulation in an attic does not need to be covered provided the attic is for intermittant access or storage and not part of a habitable space. Seems as if the owner 'planned' to convert this attic to habitable space and never got around to it. As long as it remains an 'attic' there is no problem... |
I don't think it would ever be used as anything but dead space, the only access is through a 24"x24" scuttle hatch and has about 4' of head room at the peak.
And again, it is baffeled at the sheathing from soffit to ridge vent and therefor does have adequate ventilation, the ventilation between the roof insulation and ceiling insulation is a different story. I am still concerned with the paper vapor barrier on the roof as it can hold moisture and allow mold to form in the insulation and on the rafters, also there is a light fixture and switch in this space, so the paper is also a potential fire hazard. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
Well, don't write it up as a problem per se, just write it up as a concern and have them acknowledge that you noted the issue and have addressed it, and recommend that they bring someone in to evaluate the situation and make a recommendation. That way you haven't committed overkill, you haven't ignored it, you haven't inflamed the client and you have protected the safety of your client, the homeowner and yourself as well as your peace of mind.
