Old 1/2/10, 12:15 PM
Joe Funderburk, CMI's Avatar
Default Window component identification and defect description please
What do you call the mechanism at the sides of the window for modern, vinyl (or wood) windows that attaches to the bottom of the sash? How do you describe the defect when the mechanism isn't attached? It sometimes keeps the sash from staying raised, and definitely affects the tilt function because the lower sash tilts and may fall out of the frame when you try to tilt it.
1st photo shows a disconnected mechanism. 2nd shows one correctly attached.
Thanks.
window-component-identification-and-defect-description-please-010110-096.jpg window-component-identification-and-defect-description-please-010110-078.jpg
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Find an InterNACHI certified Tennessee Home Inspector (and anywhere else in North America)
Old 1/2/10, 12:29 PM
Bruce A. King's Avatar
Default Re: Window component identification and defect description please
good question....
try something like this
The xxxx window has disconnected or broken hardware along the frame edge(s) that prevent proper operation. This affects both the use of and the safety of the window.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 1/2/10, 12:36 PM
Thanks. For some reason, Kevin Costner kept coming to my mind saying, "Engage the mechanism". (For the Love of the Game).
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/2/10, 12:40 PM
James A. Levy's Avatar
James A. Levy James A. Levy is online now
When I worked for The Home Depot, customers would bring them in for replacement on their American Craftsman vinyl windows. The name of the replacement part was a "sash balance". That is all I've ever heard them referred to.
Old 1/2/10, 12:54 PM
Michael Larson's Avatar
Balance mechanism.
Michael Larson
Hudson, WI
[/I]
Old 1/2/10, 12:55 PM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
A little thingy on the bottom of the window is busted. You might want to get it fixed
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 1/2/10, 12:56 PM
Track mechanism.
Michael Larson
Hudson, WI
[/I]
Old 1/2/10, 1:25 PM
Michael, do you want to try a third time?
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/2/10, 1:28 PM
Spiral thingy dingy?
Michael Larson
Hudson, WI
[/I]
Old 1/2/10, 1:34 PM
Adjust Tilt Window Spiral Balance
If your tilt windows require adjustment, such as sash dropping or pulling up, or if the spiral rod is disengaged, adjustment is simple:
  1. Tilt sash downward to expose balance shoe. Using diagram 1, disengage rod from shoe. Do not disconnect rod from tensioning tool.
    1. Rotate rod slightly to the right.
    2. At the same time, pull rod downward.
    3. Slip rod away from the pivot lock shoe.
  2. If sash is dropping, add tension by rotating rod clockwise. Do not exceed more than two full turns at a time, doing both sides equally. Reconnect rod, repeat process if needed.
  3. If sash is pulling up, less tension is required. do both sides equally; rotate rod counter-clockwise one turn. Reconnect rod; repeat process if needed.
  4. If rod is disconnected from shoe then follow diagram 2, for position of rod before connecting rod and balance. Apply tension to both sides equally, not exceeding four turns at a time.
Michael Larson
Hudson, WI
[/I]
Old 1/2/10, 1:43 PM
Michael is correct, it is the balance system for the operation of tilt, single and double hung windows.
Sometimes the Manufacturers will mess up and the balance systems will allow the top sashes of double hung windows to creep down.
This means that the balance was improperly sized for the weight of the window sash and when one is broke or disconnected, the operation of the window sash will not operate adequately and in need of repair.
Old 1/2/10, 3:46 PM
Window Terms Glossary
Air Chambers
Small honeycomb spaces within the sash and frame which help to insulate and strengthen the window
Air Infiltration
The amount of air that passes between a window sash and frame. In windows it is measured in terms of cubic feet or air per minute, per square foot of area. The lower the number, the less air the window lets pass through.
Air Latch
Latch mechanism on the interior face of the sash that retains the window in a partially open position for ventilation.
Angled Exterior
A sloped extension from the frame that adds an aesthetically-pleasing dimension to the exterior of the window.
Argon gas
Argon is a safe, odorless, colorless, non-toxic, non-flammable inert gas that is commonly used in place of air between the glass panes of an insulated Low-E glass unit to reduce temperature transfer.
Astragal
The center member of a double door, which is attached to the fixed or inactive door panel.
Awning window
A window unit in which the bottom of the sash swings outward for ventilation.
Balance System
Device for holding vertically sliding sash in any desired position through the use of a spring or weight to counterbalance the weight of the sash.
Bay window
A composite of three windows, usually made up of a large center fixed unit and two flanking units at 30-,45- or 90- degree angles to the wall.
Old 1/2/10, 9:44 PM
Thanks everyone. I had googled it earlier but didn't find anything useful.
Theodore Roosevelt
Joe Funderburk, CMI
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 294 2/10/08 1:20 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
