Old 3/18/08, 4:36 PM
Richard L. Bennett Richard L. Bennett is offline
Default Window Glass Type
Ran into some plastic windows on an inspection and the question is are they required if the window is close to the floor and a certain size??
My client thought they should be glass so a person could break and get out in case of a fire.
I think that they were broken and replaced by a contractor that saw a possiblity of being sued if he did not use something that was break resistance
These windows are quite low to the floor
I have been all over the net and can't get a reading on this
Thanks in advance
rlb
Old 3/18/08, 5:07 PM
mnahrgang's Avatar
Default Re: Window Glass Type
Hey Richard.
Probably plexiglass. Pretty common as a safety precaution.
When my little sis was about 7yrs old, she accidentally put her arm through a glass window on my Grandma's storm door. She could have very easily bled to death. Fortunately, through good first aid, and a quick trip to the hospital, the only lasting effect she has today is a nasty scar on her wrist.
Grandpa replaced the window (and all the other low windows) with plexiglass, to keep from ever happening again.
So from my own personal experience I would be more concerned with keeping the glass from breaking than from being trapped inside. A good kick can take the entire pane of plexi out without breaking it into shards. IMHO the plexi is a good thing.
(On a negative note, it does scratch up fairly easily, and it looks bad after a couple of years.)
Mark Nahrgang
www.HeyMark.info
Old 3/18/08, 5:13 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
The drummer from the band Abba died last week from a cut he got when he broke a window in a door with his head. (from what I understand)
Old 3/18/08, 5:17 PM
Try this:
Larry Kage, CMI
231 929 3525
Old 3/18/08, 5:24 PM
Thanks in advance
rlb
Those particular areas of glass should be of tempered or safety glass as recommended in the IRC R308.4 Hazardous locations.
If the window or door is made for emergency egress, it should not be aticipated that the glass needs to be broken, it is assumed it will be operable.
JMO
Marcel
Marcel
Old 3/18/08, 5:31 PM
Larry
I think you nailed it
rlb
Old 3/18/08, 10:23 PM
Bob Elliott's Avatar
Plexi-glass can also be very flexable an prone to push right out of the glazing,
depending on the situation.
The only place I expect to see it is on Ghetto vestibule doors.
I would not call it acceptable on a regular window.Tempered glass may be required as stated above.
Old 3/18/08, 10:36 PM
The plexie glass that was installed was done very professionaly and was in good condition. Could not tell it from glass until I hit it with a screw driver handle
Buyer thought it was an issue -- After checking it looks like it might be required in the location that it is installed
In any case I reported it as POSSIBLY correct
I did not take measurments on site but the windows were very low to the floor
If it had been my home I would like to see the plexie or other safety glass in the windows -- esp if I had young kids -- call it common sense
Thanks all
rlb
Old 3/19/08, 9:11 AM
Barry Adair's Avatar
Must read! imo
Approved plastics that meet the ANSI Z97.1
Standard are another form of safety glazing.
Limitations on its acceptable use arise from
fire resistance ratings. In garages, inspectors
may find that original glass panels in exterior
passage doors have been replaced with
plastic. While it may provide safety, a
disadvantage of plastic is that it easily
becomes permanently scratched. Plastic is
often used in skylights.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Commercial Electrical Inspections jtedesco1 Commercial Inspections 29 1/12/08 5:03 AM
Window well finishing rmuller Interior Inspections 7 5/10/07 8:11 PM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 7 4/23/07 7:31 AM
Clarification on Safety Glass jweinberg General Inspection Discussion 4 12/25/06 1:35 AM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 3:38 AM
