Old 5/26/09, 6:02 PM
Jeffrey A. Prince Jeffrey A. Prince is offline
Default Window height and temperance
Hi Guys
Quick question about sill height. Seems to be some different opinons. If a window sill height is below 36" but it is not in a location such as stairs or landing does it need a guard and does it need to be tempered ? The window in question was about 2' feet from the floor in a dining room
Safe At Home Inspections,Inc.
Home Inspections performed in Darien, Downers Grove, Lisle, Westmont, Woodridge, Naperville, Aurora, and all surrounding areas in Greater Chicagoland.
630-437-1572
Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America)
Old 5/26/09, 6:18 PM
James H. Bushart's Avatar
Default Re: Window height and temperance
There are a variety of contingencies and your description is incomplete. Refer to IRC 2006, Section 308, with your question and you will find your answer.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 5/26/09, 8:33 PM
Brian E. Kelly's Avatar
I just found this on the code check site. You can download it.
http://www.codecheck.com/cc/images/S...gArticle07.pdf
Old 5/26/09, 8:50 PM
Thanks Brian. I think that helps
630-437-1572
Old 5/26/09, 10:16 PM
Wade Williamson Wade Williamson is offline
Do all pieces of tempered glass have to be marked? I was at an inspection today with glass on the side of a staircase, about 5 different pieces and only one had the tempered glass stamp.
Wade Williamson
Axium Inspections
Colorado Home Inspection
Old 5/26/09, 10:33 PM
http://www.nachi.org/safety-glass-for-inspectors.htm
R308.1.1 Identification of multipane assemblies. Multipane assemblies having individual panes not exceeding 1 square foot (0.09 m2) in exposed area shall have at least one pane in the assembly identified in accordance with Section R308.1. All other panes in the assembly shall be labeled "16CFR1201
Old 5/27/09, 12:53 AM
Thanks Brian.
Wade Williamson
Axium Inspections
