Old 2/22/06, 6:07 PM
jwortham jwortham is offline
Please Note: jwortham is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Window Install
I am looking for opinions on the install of this window.
There were 6 others just like it. Looks wrong to me.
Any help would be most appreciated!
Old 2/22/06, 6:12 PM
Joseph Hagarty,  CMI's Avatar
Default Re: Window Install
Jeff:
What type of window (manufacturer) is this?
Reference the Window Manufacturer's recommendations for the installation to properly report the deficiencies that are present.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 2/22/06, 6:38 PM
Carl A. Brown's Avatar
It almost has to be wrong!!!
Old 2/22/06, 7:38 PM
I agree.
However, you need to Reference and Substantiate your Findings.
Joseph P. Hagarty
Phone: 610-399-3675
Old 2/22/06, 8:40 PM
Common sense!!! Out the window.
http://www.thewindowinfosite.com/vinylwindowsanddoors
Old 2/22/06, 9:11 PM
Joe, I have no idea. I took one look at it and went "What the $%^&?"
I couldn't see behind the aluminum siding to check if there was another flange or any flashing and couldn't see how this setup would keep water outside the building envelope. So I wrote it up as "appears to be improperly installed".
Have spent the last day online and in the local building centers looking for anything like these and have come up with zero.
Old 2/23/06, 4:47 PM
bjones1 bjones1 is offline
Send a message via MSN to bjones1
Please Note: bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
How did this window look from the inside? I've seen this before, or something like it, and it occurred when the home-owner installed the window, squaring, levelling, and nailing, all from the inside, in order to be flush with his walls. It was in an older home, nothing was square, straight or level.
Old 2/27/06, 9:06 AM
msaxton msaxton is offline
Ive installed alot of various types and styles of window in my day,and one look at that and there is no doubt that it is way wrong, with the flange outside of the siding I suspect the same thing as brian, installed to meet up with the inside wall with no regard to the important matters such as water intrusion
Old 2/27/06, 9:24 AM
There was no trim. It was actually recessed in and drywalled.
Nice work on the inside, but wrong as I am learning.
You know the old saying, "If it looks wrong, it probably is!"
Old 2/27/06, 10:12 AM
William J. Decker's Avatar
Jeff;
A good point to remember. We don't have to fix it or expain how it should be. We just have to recognize that it is wrong. I would report:
"Windows improperly installed. No drip flashing and there appears to be no interior flashing or water seal. Gaps between window and siding leave room for water infiltration which can lead to wood rot and organic growth (mold).
Recommend evaluation and repair by a licensed and insured window contractor before the close of escrow."
You described the window, its condition and the possible risks if not fixed. You recommended what whould be done to fix the problem and the time frame that it shluld be done in, in order to protect your client. Can't do more. No need to get to specific. If you do and you make one little misstatement, they can hang you for it.
Hope this helps.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 2/28/06, 9:33 AM
Will,
Just looking for my own edification. I am always looking to learn something new. Hence, I ask questions!
Old 2/28/06, 9:49 AM
Edifying yourself in public?
How kinky.
Will Decker, CMI
Old 2/28/06, 10:21 AM
twheeler
Guest
Posts: n/a
A drip cap would be good, and easy to install, that would avoid having to caulk every year.
Old 2/28/06, 6:26 PM
pkelley's Avatar
pkelley pkelley is offline
Looks as if the window capping was installed with improper dimensions used . Barney Fife held the tape the wrong way The sad part even though it looks pretty from 5 feet away water,snow will go behind that capping and if it is caulked between the capping and the window all around , water will look for a place to go .be it behind the siding into the wall itself or in the house and rot everything away
Old 2/28/06, 6:42 PM
This type of window installation was never part of the standard installation for any window. I have never seen anything like it.
Wood suggest and recommend highly that a Prominent Building Contractor approved by Anderson Window Corporation or Equal, make an Estimate for the proper repair.
This installation is drastically wrong and needs to be corrected at some cost to the owner.
Marcel
</IMG></IMG>
Window well finishing rmuller Interior Inspections 7 5/10/07 8:11 PM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 7 4/23/07 7:31 AM
Window installation jmichalski Exterior Inspections 17 1/24/06 9:42 PM
