There was a 45 degree angle between the door and the window to the right. The window was about 17 inches from the door edge. The "arc" rule below causes me to scratch my head. Note: a mentally handicapped child will be occupying the home.
Hazardous Locations: "Glazing, in an individual fixed or operable panel adjacent to a door where the nearest vertical edge is within a 24-inch (610 mm) arc of the door in a closed position and whose bottom edge is less than 60 inches (1524 mm) above the floor or walking surface."
| Find an InterNACHI certified Florida Home Inspector (and anywhere else in North America) |
You mean a 135 degree angle I think.
Looks like any window within 24 inches that is less than 60 inches off the floor needs tempered glass. The "arc" is used to include any window within 24 inches regardless of the wall angles. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Looks like it is more of an issue from the deck side.
The door does open into a screened porch.
I think the rule is intended to prevent the window from shattering if the door slams or to prevent shattering if someone is carrying something in their hands that hits the window. Where the door opens to is irrelevant I believe. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Depends on your orientation. If the vertical axis is the wall with the door, then the wall with the window is 45 degrees. That's how I look at it.
Here's one from today. Note the window at a right angle to the door. The door would not actually strike the window. But should it be tempered? Age of home: 2000.
I don't understand the diagram and it seems to be incorrect. I don't know how you can take the swing of the door into account when the 2006 IRC states that the measurement of 2 feet from the door is with the door in a closed position.
"Glazing, in an individual fixed or operable panel adjacent to a door where the nearest vertical edge is within a 24-inch (610 mm) arc of the door in a closed position..." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
From a previous discussion.
http://www.nachi.org/forum/f18/safet...684/#post88381 See the diagrams at the end of the PDF for some clarity You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Joe, I didn't verify Jerry's picture from your link but typically he has good info R308.4(5) and R308.4(6). InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Thanks, Michael. I forgot about that one. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I like the diagrams in this on even better. Especially for near stairways.
http://henricotoday.com/bldg/pdf/Tem...sAdditions.pdf You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
That doc says one thing in the diagram and another in the text, it don't add up.
Look at the top right of page 2. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Those diagrams make sense. Now I completely understand how the 24" arc works. Thanks.
| Need help flashing top of replacement window on brick wall !!! | Bill Featherstone | Exterior Inspections | 5 | 6/26/10 10:25 PM |
| Non Tempered New Window | jevans | Interior Inspections | 42 | 3/9/09 7:44 PM |
| Leak in bay window with copper roof | hmiles | Exterior Inspections | 19 | 11/22/08 8:37 AM |
| Window well finishing | rmuller | Interior Inspections | 7 | 5/10/07 8:11 PM |
| CPA of Health Canada reminding us of corded window coverings. | gromicko | Canadian Inspectors | 7 | 4/23/07 7:31 AM |
