This seems to be a generic problem on a lot of the one year warranty inspections that I do. At first I thought it might be too much spray foam but then I realized that the painting and caulking takes place long after the spray foaming is done. Any ideas?
| Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Shrinkage occurs over time. |
cboyd is a non-member guest and is in no way affiliated with InterNACHI or its members.
Bob's right, the jamb extensions likely shrunk and pulled away from the vinyl window. Same idea in why you probably see lots of nail pops in the drywall in the first couple of years And why do we call them "nail" pops...? Nobody uses nails for drywall anymore...
That coupled with contractors grade caulk.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Msight have been a cheap caulk and shrinkage, but the stool should have been installed higher than the bottom of the replacement window. Or the replacement window should of been measure properly.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Strange that it always occurs at the bottom rather than at the top or sides though.
No sags here Bob.
Fact #2... They love to solve #1 with all the shims at the bottom Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Looks like a lack of shimming at time of installation . IMO
galaxyhomeinspections.com An amateur built the Ark ! Professionals built the Titanic ! |
![]() Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Not to mention the lovely look of raw "Great Stuff" hehe.
The only thing I use that for is making molds.eeech. |
It makes an awesome foundation repair/sealant!!!
If you have gaps in the foundation big enough for the big gap stuff, you have other issues at hand.
| Need help flashing top of replacement window on brick wall !!! | Bill Featherstone | Exterior Inspections | 5 | 6/26/10 10:25 PM |
| CPA of Health Canada reminding us of corded window coverings. | gromicko | Canadian Inspectors | 7 | 4/23/07 7:31 AM |
| Window installation | jmichalski | Exterior Inspections | 17 | 1/24/06 9:42 PM |
